Link an external bookmark
Nov 21, 2007 Nov 21, 2007
Hi
I would like to link a bookmark from a subproject to a topic from a master project.
I follow instructions: compile subproject, merge subproject in the TOC’s master, click “insert link” and select “Link to Remote Topic”
At this step, I see all the topics but no bookmarks .. Is there a solution to solve it ?
I have RoboHelp X5
Thanks for your answer
413
LEGEND , Nov 21, 2007 Nov 21, 2007
Hi Manoun.
I got to thinking that you could manually add #bookmarkname after the URL to the remote topic but this does not seem to work. Then I got to wondering if a redirect topic is the answer. Check out how to do re-directs via Rick Stone's tips n trricks file.
Hi Manoun.
Hi Colum
Thanks for this. But, I have read the trick and it seems not corresponding for my problem 😞
Hi Manoun.
What I was suggesting was to attack the problem in a different way. You can't link to a bookmark in a remote topic as RH doesn't allow you. So if you add a "normal" hyperlink to a redirect topic in your project that just jumps to a topic in another CHM and then jumps to a bookmark in that topic, this would get around the problem. The key to getting this to work is to specify the path to the bookmark correctly. I can't think of a reason why this wouldn't work.
Are you saying it doesn't work or that you can't see how this would do what you want?
Dec 12, 2007 Dec 12, 2007
Hi Colum
Thanks again for your suggestion. IT WORKS !!
Sorry to be so negative
RoboHelp Documentation
Download Adobe RoboHelp
