Revision: 3598
Author: gauravj@adobe.com
Date: 2008-10-13 13:32:58 -0700 (Mon, 13 Oct 2008)
Log Message:
Modifying the build files to update the swcs with dita based asdoc xml files.
The dita xml files should go under the docs folder inside the swc.
QA: No
Doc: No
Tests: checkintests
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/build.xml
flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
flex/sdk/trunk/frameworks/projects/flex/build.xml
flex/sdk/trunk/frameworks/projects/flex4/build.xml
flex/sdk/trunk/frameworks/projects/framework/build.xml
flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
flex/sdk/trunk/frameworks/projects/rpc/build.xml
flex/sdk/trunk/frameworks/projects/utilities/build.xml
