Revision: 3625
Author: gauravj@adobe.com
Date: 2008-10-14 09:37:56 -0700 (Tue, 14 Oct 2008)
Log Message:
Retry the change to update the swcs with dita based asdoc xml files.
But this time with lazy read set to true.
QA: No
Doc: No
Tests: checkintests
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/build.xml
flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
flex/sdk/trunk/frameworks/projects/flex/build.xml
flex/sdk/trunk/frameworks/projects/flex4/build.xml
flex/sdk/trunk/frameworks/projects/framework/build.xml
flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
flex/sdk/trunk/frameworks/projects/rpc/build.xml
flex/sdk/trunk/frameworks/projects/utilities/build.xml
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
