Revision: 3638
Author: gauravj@adobe.com
Date: 2008-10-14 16:49:56 -0700 (Tue, 14 Oct 2008)
Log Message:
Changing the build order of swc file update with dita xml files.
By default this would now happen during the checkintests target - so "ant clean main" shouldn't get affected.
To opt out use -Dno.doc=true
QA: No
Doc: No
Tests: checkintests
Modified Paths:
flex/sdk/trunk/build.xml
flex/sdk/trunk/frameworks/build.xml
flex/sdk/trunk/frameworks/projects/airframework/build.xml
flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
flex/sdk/trunk/frameworks/projects/flex/build.xml
flex/sdk/trunk/frameworks/projects/flex4/build.xml
flex/sdk/trunk/frameworks/projects/framework/build.xml
flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
flex/sdk/trunk/frameworks/projects/rpc/build.xml
flex/sdk/trunk/frameworks/projects/utilities/build.xml
