So here's what I needed to do to get this to work with CF7:
1. Edit wwwroot/WEB-INF/client-config.wsdd to use
CommonsHTTPSender per the Tom Jordahl blog post (
http://tjordahl.blogspot.com/2007/03/apache-axis-and-commons-httpclient.html).
2. Put commons-httpclient-3.1.jar and commons-codec-1.3.jar
into CFusionMX7/lib. These jars are available from the Apache
Commons project (
http://commons.apache.org/).
3. Add a web service entry in the CF Administrator. For the
sample code to work, use the name MapPoint. The URL is the normal
staging wsdl (
http://staging.mappoint.net/standard-30/mappoint.wsdl),
and the username and password are the ones issued by Microsoft for
your mappoint account.
The CF application service needs to be restarted to pick up
the apache commons jars. At this point, the sample code should be
runnable. It displays an input field which you can type an address
into (e.g. "1 microsoft way, redmond, wa"), and displays a map when
submitted. The code is fairly simplified and ignores things like
the possibility of multiple find results.
Since this is entirely done in CFML, some of the helper
objects used as function inputs need to be built up as CF structs
mirroring the data members of the java objects. This is problematic
in creating a MapView object because there's no way to indicate
which of the derived classes (ViewByHeightWidth, ViewByScale, etc)
you intend. My workaround was to use a view object returned by
GetBestMapView().
Hope this will be helpful to somebody.
James
