1. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Greene.r Jun 7, 2009 8:58 AM (in response to (Frank_Spangenberg))I have the same keywords duplication problem (Acrobat 9.1.1 Pro, Windows XP Pro sp3).
Has there been a fix?
Or is there a workaround?
2. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Frank Spangenberg Jun 26, 2009 4:57 AM (in response to Greene.r)Not fixed in Acrobat 9.1.2.
Problem was reported and accepted as a bug in October 2008.
Only workaround is to modify the metadata with an external tool, Acrobat's scripting engine cannot do this job…
3. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Greene.r Dec 2, 2009 11:29 AM (in response to Frank Spangenberg)Is there hope for a fix on this duplicate keywords problem -- soon?
It is a BIG PROBLEM with Acrobat 9's PDF/A conversion, but surely it is a little matter for Adobe to fix it via a patch.
4. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Greene.r Jul 19, 2011 10:18 PM (in response to Greene.r)As far as I can tell, the problem of duplicate keywords on PDF/A files made by Acrobat has been fixed with Acrobat version 9.4.5.
Can anyone confirm that, please?
5. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Frank Spangenberg Jul 20, 2011 4:08 AM (in response to Greene.r)In the meantime I switched to Acrobat X, where this bug doesn't appear.
6. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Greene.r Jul 20, 2011 4:35 AM (in response to Frank Spangenberg)Frank,
Thanks for your posting.
Have you experienced any downsides in moving from Acrobat 9 to Acrobat X?
Raphael
7. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
primepal Jul 20, 2011 6:18 AM (in response to Greene.r)should be a fine switchover
8. Re: Acrobat 9: Keywords are duplicated on PDF/A conversion
Frank Spangenberg Jul 20, 2011 6:23 AM (in response to Greene.r)Well, they changed the user interface dramatically and moved some features around. So if you had a kind of a custom workflow within Acrobat you might need to adapt it to the new interface and feature locations. Just try it out using the trial version! :-)
