3 Replies Latest reply: Mar 1, 2009 3:58 AM by AbhigyanModi RSS
    Acrobat 7 PDF from webpage
    GESYMSB Community Member
      I do a lot of savings as PDF from web pages when on-line
      However My Acrobat 7 always include the web address on the very top
      and the bottom of the page, how can I stop Acrobat from including the web
      addresses on my PDF pag(s)
        • 1. Re: Acrobat 7 PDF from webpage
          Bill@VT CommunityMVP
          If you are printing from a browser, adjust the printer selections in your browser. If you are opening the web page in Acrobat, select the options (or similar name like Conversion Settings in AA5) button at the bottom of the opening window. You should also be able to set these in the EDIT>Preferences under the "to PDF" tab.
          • 2. Re: Acrobat 7 PDF from webpage
            I found a couple of things but still the same.
            Let me tell you how I do it.
            I found a page that I want to save as PDF.
            I could printed to PDF or click on the Adobe Icon on the
            Explorer, you will get the dialog "Convert Webpage to PDF"
            waiting for you toset name & folder.
            Ok, everything goes find, but ALWAYS, the name of the page
            will be on the very top ( in small case ) and so is the
            web Address at the bottom of the page.
            Thanks for responding
            BTW: Can't find this on Preferences..
            • 3. Re: Acrobat 7 PDF from webpage
              AbhigyanModi Adobe Employee
              Or
              - create a web page from Acrobat - File>Create PDF>From web page
              - type any valid URL
              - Click settings button, uncheck the option to add headers and footers
              - Press OK, and convert the web page
              Your preference would be saved and next time you create PDF from IE using Acrobat button or from Acrobat using Create PDF>From web page, you won't see any headers/footers.
