Can FDS & Flex Server 1.5 co-exist on the same server? This is not a long-term configuration but we will need to support both as we migrate all our Flex 1.5 apps to Flex 2. Does anyone know of any issues running both servers as standalone (not J2EE) installations?
The following has evaluated to null or missing:
==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41]
Tip: It's the step after the last dot that caused this error, not those before it.
Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing#if>. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)??
FTL stack trace ("~" means nesting-related):
- Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5]
