Show 2 replies
1. Re: Bridge CS4: Workspace settings won't stick?
Omke Oudeman Oct 30, 2008 2:23 AM (in response to Rafael Aviles)You are right, for some reason you can not alter the preset Workspaces that came by default.
Create your own workspace starting from the default essentials. Right Click on each tab you want to remove and choose close.
Drag the content panel to the size you want and choose the size of the thumbnails. Then choose new Workspace from the drop down menu and rename the new work space. You could also choose for the other options about location and sort order which can be very useful. -
2. Re: Bridge CS4: Workspace settings won't stick?
Rafael Aviles Oct 30, 2008 12:10 PM (in response to Rafael Aviles)Thanks, Omke! That worked (starting from the Essentials).
Rafael
