SOLVED
CF/Flex Application Wizard
Avatar
Level 1
I am trying to use the wizard for a tutorial. When I get to
the RDS and Data Source Selection screen, I have and RDS server in
the dropdown (Localhost), but nothing in the Default Data Source
dropdown!?
I have set up a datasource using the CF administrator
screens.
Sorry, I'm totally new to CF - Any suggestions on what to
check?
Mathias
1 Accepted Solution
Avatar
Correct answer by
Level 1
Never mind, I figured it out.
I'm Using IIS
I needed to go look at the properties.
On the web site tab, the TCP port was set as 80.
In FlexBuilder Window > Preferences > Cold Fusion >
RDS Configuration
Select localhost > The default port number added there was
8500
Once I changed that to 80 and clicked on test connection, all
was hunkey dorry
1 Reply
Avatar
Correct answer by
Level 1
I'm Using IIS
RDS Configuration
8500
was hunkey dorry
