Show 12 replies
1. Re: Error message when opening RAW from Bridge to CS2
Omke Oudeman Sep 12, 2007 12:42 PM (in response to (Trevor_Sims))Have you tried to renew preferences in Photoshop?
Are you on MAC or Windows? -
2. Re: Error message when opening RAW from Bridge to CS2
(Trevor_Sims) Sep 12, 2007 1:01 PM (in response to (Trevor_Sims))I'm on Windows and had RAW plug-in 3.0 and now have 3.7.
I have never touched the settings in Preferences so I have no idea what they should be. Is there a standard guide somewhere I could look at for the settings?
Thanks. -
3. Re: Error message when opening RAW from Bridge to CS2
Omke Oudeman Sep 12, 2007 11:30 PM (in response to (Trevor_Sims))After renew settings in preferences the basic set from PS is active. Go trough it and look around what you can use, explore it.
Most important is scratch disk setting, ammount of RAM and I find it useful to change the cursor setting to the last checkboxes.
Read the manual that came with your copy and or try one of the thousands tutorials that are available either free or for sale. There are very good DVD's that shows you the screen from the teacher on your own screen and so you can see what he or she does. Total Training is a good start but there are others.
start here and find your way: http://www.adobe.com/training/ -
4. Re: Error message when opening RAW from Bridge to CS2
Ramón G Castañeda Sep 12, 2007 11:58 PM (in response to (Trevor_Sims))Trevor,
Omke is referring to rebuilding Preferences in the application.
Just hold down Command+Option+Shift immediately after relaunching Photoshop or Bridge. Timing is critical.
All your preferences settings will revert to the default settings. -
5. Re: Error message when opening RAW from Bridge to CS2
(Trevor_Sims) Sep 13, 2007 1:30 AM (in response to (Trevor_Sims))Hi Ramon,
Sorry to be such a dumbo but where on the keyboard is Command+Option+Shift?
I have shift = up arrow
Then I have control, alt & alt gr
Is it a combination of those?
Thanks.
Trevor -
6. Re: Error message when opening RAW from Bridge to CS2
Ramón G Castañeda Sep 13, 2007 1:33 AM (in response to (Trevor_Sims))Sorry, Trevor. Because Omke and I are both Mac users, I assumed you were one too. I focussed on Omke's reply and the lack of specificity in your original post. My bad.
Next time, try to give a hint as to your platform and OS. -
7. Re: Error message when opening RAW from Bridge to CS2
PECourtejoie Sep 13, 2007 2:50 AM (in response to (Trevor_Sims))CTRL+ALT+Shift on PC -
8. Re: Error message when opening RAW from Bridge to CS2
(Trevor_Sims) Sep 13, 2007 3:50 AM (in response to (Trevor_Sims))Right got that. It's back on track. I don't remember making any changes. Any suggestions as to why it might have gone off like that?
I'll remember next time to be more explicit about my PC.
Trevor -
9. Re: Error message when opening RAW from Bridge to CS2
PECourtejoie Sep 13, 2007 5:59 AM (in response to (Trevor_Sims))Just make sure to properly close Photoshop, Bridge... before shutting down your PC. If there are electrical problems at your home, that cause sudden shutdowns (I had the case, micro surges), invest in a Uninterruptible Power Supply. -
10. Re: Error message when opening RAW from Bridge to CS2
Ian Lyons Sep 13, 2007 8:50 AM (in response to (Trevor_Sims))To reset Bridge preferences you need only hold down the Alt/Option key when launching the application. -
11. Re: Error message when opening RAW from Bridge to CS2
SG...Sep 13, 2007 10:38 PM (in response to (Trevor_Sims))
Ian's comment is only true for Bridge CS3. The dreaded 3 key with timing is needed for Bridge CS2.
cheers -
12. Re: Error message when opening RAW from Bridge to CS2
(Trevor_Sims) Sep 13, 2007 11:32 PM (in response to (Trevor_Sims))Thanks for that . It's CS2 I have and the 3 key method worked.
T
