Anyone know exactly what this means?
Oct 14, 2007 Oct 14, 2007
It works from Monday - Saturday, but bombs on Sunday
Message Incorrect number of columns in row.
Detail Verify the number of columns specified in the columns attribute and
in the target file
What exactly does this mean and what should I be looking for?
I found this on google, but no resolution. Any ideas? Anyone know an
alternate custom tag that can be used on a shared host?
"Note: this only works if your columns do not contain a carriage return!
You get a "Incorrect number of columns in row"
For example: if you have a webapplication with database that has a
memo-field (html textfield) and you have one or more carriage returns in it,
these are (ofcourse) also stored in the database.
Now if you cfhttp to a webpage that returns these database-results in a
html-page, you get a page with extra carriage returns at the position of the
carriage return from the memo-field.
Every line in the http-response must be one row!"
Wally Kolcz
MyNextPet.org
Founder / Developer
586.871.4126
Advanced techniques
262
> in the target file
i assume this question relates to your trying to read txt/csv files into
your db, right?
it then can mean:
a) depending on the way you read files into the db: that at least one
row of data has fewer or more items than expected (defined by the header
row or by some rule imposed by your code, like number of columns of data
to expect)
b) as in the googled explanation: that at least one of the fields/items
in the imported data has carriage returns stored in it, which ends the
current data row with fewer data columns than expected.
i suspect that on sundays you get your data in a bit different format
than on other days...
one way to get around the problem (if you can't change/enforce data
model integrity) would be to
- read your data file in row by row
- in each row replace all carriage returns except the end-of-row one
with spaces
- check each row for correct number of data columns: import data if all
correct; otherwise do not import that row, store the row data in some
var/file and review later to see what was wrong with it
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Documentation
