What my IT Dept stated re: b00, b01 and b02 files...
Subject: RE: What are .b00, .b01 and .b02 files (for)?
Short answer, they are usually a form of drive image file
from possible from daemon tools… however I have seen these
extensions associated with split files… but they are usually
have the same filename.001 filename.002 filename.003.
BUT. They all have the date of 6/17/07 which is related to a
document you would have worked on, also with the actual naming of
the files, makes the it more apparent. I would not delete them.
They are also in the other folders you have which are dated.
Author's postscript...
I misread this note and deletetd the files. Then I generated
a new project. I noticed no issues. However, I decided to replace
the deleted files anyway, just to be on the safe side.
