I am having the same problem, I down load from public library and it does not end up in the Adobe Digital Edition. you are not alone
Can you give us more information? What OS are you using? What version of ADE? Which steps are working for you, and at what point do they stop working?
Also, are you sure you downloaded the book? I had a library patron come in the other day and ask about something similar, but it turned out that she did not realize that the system our local library uses to check out ebooks required two separate steps: first you had to check the book out, then you had to download it.
If you have downloaded the book, see if you can search for the file (if you don't know the file name, try just searching for .acsm). Once you find the file, right click on the file name and choose Open With - Adobe Digital Editions. That should open the file in ADE, allowing you to then transfer it to your device.
I am using Vista, and yes we are checking the book out and then downloading. I can download to my daughter-inlaw laptop just fine.
