Binding a control to a cfc with multiple triggers
Oct 18, 2007 Oct 18, 2007
I'm an old-school coder. I've been trying to figure out the new AJAX controls to see if they could save me some time, but I'm running into headaches.
At the moment I'm building a tool to reconcile a table full of firstname lastname and organization records (strings, no id's) with 2 other tables that contain organizations and contacts, respectively. IOW, we're trying to match string data with records that have ID's.
My tool so far has 3 form fields per record - a "this is valid" checkbox and 2 select lists. One for organizations, second for the contacts associated with that org. On load, I bind the org select to a CFC that attempts a direct lookup using the string value of the record, then a SOUNDEX match. Now, when the select list gets loaded, I want to use the first matched record's ID to lookup contacts for that org. How do I tell the second select list to wait until the first one is loaded before doing its lookup, and to do another lookup anytime that value changes? What if I wanted to also link the lookup functionality to the checkbox 's onChange event? I may want to add a separate checkbox so there is one for org and one for contact in case an org exists but the contact doesn't.
Advanced techniques
271
1) in your contacts cfselect make sure you have specified
bindonload='false' - this will prevent it from loading any data on
pageload, before an entry in your organisations list is selected
2) in its bind argument add @change to the bind parameter: i.e.
bind='cfc:path.to.your.cfc.method({formcontrolname@change})' - this will
make it re-lookup data on each change in the organisations list (it may
be that @change is even default event, so you may not even have to add
it at all... can't remember now if it is change or click that is default...)
3) how do you want to link your select lists to your check boxes? what
action should the change in the state of a checkbox trigger?
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
onChange I would think. Thanks for the help. I was able to get this far, but I still don't know how to add the second triggers.
what second trigger do you want to add?
basic bind code is like:
bind="cfc:path.to.cfc.method({trigegr1},{trigger2},...,{triggerN},someintegervalue,'somestringvalue')"
your called cfc method must accept N+2 arguments in pre-defined order
Azadi Saryev
Sabai-dee.com
Documentation
