This worked for me as well,thanks very much!!
There it is!!!! I was going crazy!!!! Thank you sir!!
Thank you so much! So problematic without the box...
Try to press and hold Shift key BEFORE object corner selection for dragging.
This is definitely a problem with Entourage, Quicken and a certain other program that I do not recall you also might have to update your Microsoft software.
Same issue I was facing and got the solution when I closed the Google Chrome brwoser where I had oppened almost 30 to 35 windows in tabs and right after closing that it got fixed.
BTW. if above trick does not work for you, you can try by closing all the other brwosers or software to work correctly the illustrator.
M khalid
Hi, I'm having problems scaling an asset that has various Fills and Strokes.
Prior to shift scaling it, i expand all the strokes so that they become fills, HOWEVER The asset seems to warp in certain areas
and doesnt maintain it's proportions. Whats going on !? can anyone help !?
Show the problem with a screenshot.
And you might want to start a new thread so everyone knows it is a different though related issue.
Is the box for Scale Strokes & Effects checked in either Preferences or the Scale dialog? You don't have to expand the strokes to fills for them to scale properly.
Hi, Thanks for the response.
I checked the box "Scale Stroke and Effects" and the problem still occurs. The top image
Is the one that i've scaled and you can see how its deformed. Any ideas.
Hi there.
An user called [scott w] solved my problem with this answere:
http://forums.adobe.com/message/3915059#3915059
You may found it usefull too.
Thank you SO much. That just saved me 2 days work. I owe you a beer.
Thanks for the help! It was driving me crazy!
