Hello,
I am following the LCDS ES sample at
http://localhost:8700/samples/#sqlassemblerfor defining a destination inside data-management-config.xml,
there you can define SQL
statements that can be referred to from MXML
I am having the following error:
'Error in SQL for 'fill' in destination 'sql-product'.
Matching pair of # tokens not found'
And the statement it is referring to, from within the
data-management-config.xml file is:
<name>getAllForServer</name>
<sql>SELECT * FROM MYTABLE
WHERE SERVER_ID = #SERVER_ID#
</sql>
I do not understand the # syntax, and how can it be used
universally? for example, setting the value of LIMIT, or variables
in WHERE statements
