7
Please Help!! "A File I/O Error Has Occurred" every time I try to save...
Sep 24, 2008 Sep 24, 2008
I'm working on a postcard design for print purposes with several embedded images and text elements. I've saved successfully several times early on, but suddenly, every time I attempt to save, I get the message "A File I/O Error Has Occurred". I need to get this to the printer, but can't make important changes now. HELP!
paul
Performance
271.5K
correct answers 2 Correct answers
Participant , Sep 24, 2008 Sep 24, 2008
Are you saving to a Server?
Save locally if you are.
New Here , Feb 01, 2015 Feb 01, 2015
Hi Larry, I am encountering the same error message...prior to today, I was able to save from CS 5 to my 8G external drive...if trash is the issue, please tell me how to empty the trash from my external drive.   - Christine
Adobe
Participant ,
Jul 14, 2020 Jul 14, 2020
Phew!! Thanks buddy!!
Aug 26, 2020 Aug 26, 2020
Great!!! thank god!!!
god bless you!!!
May 14, 2021 May 14, 2021
Thank you so much man!
Jul 15, 2022 Jul 15, 2022
Thanks man !!!!
Oct 20, 2022 Oct 20, 2022
I had problems when saving to my school Google Drive! You helpped me so much. Your a life saver. Thank you🫡.
Crazy! Wasn't saving to a server, but to a 2-gig jump drive. When I saved it to my mac's hard drive, no problem. Is there a short answer to why that happens? I didn't appear to be out of space on the external drive...
Thanks Scott!
paul
Check the Trash on the jump drive. It may need to be emptied.
Oct 26, 2014 Oct 26, 2014
Thank you. Your advice cleared my drive and I was able to fix the jump drive.  Bethddd
Make the external drive active by selecting it and opening. Then just empty the trash.
Sep 06, 2015 Sep 06, 2015
whan hard drive low space than it errar
Jul 15, 2019 Jul 15, 2019
Had the same issue (in PC) and emptying the trash was the solution. Thank you!!!
Jan 22, 2020 Jan 22, 2020
Emptying the trash doesn't work for me. I have three internal hard drives and it won't save as an .AI or .PDF to any other them. However, I can save the file as an EPS. I can also export for web. It's very frustrating.
"Emptying the trash doesn't work for me. I have three internal hard drives and it won't save as an .AI or .PDF to any other them. However, I can save the file as an EPS. I can also export for web. It's very frustrating."
Please create a new thread. It's close to impossible to further discuss in this thread, because your post can hardly be found. Also: this is old.
In your new thread please tell us your system and version and exactly where you are saving.
Participant ,
I can't say specifically, the File I/O error clearly indicates that Illustrator can't write to wherever you are asking it to write to. Could be a server without proper permissions, a jump drive formatted as NTFS, a Diskette that's full or locked, etc.
Nov 13, 2015 Nov 13, 2015
Empty the trash on the computer after selecting your jump drive or external drive. that worked for me. Thanks
Sep 19, 2017 Sep 19, 2017
Just clearing the drive you are saving to helps or try saving it to another drive.
Apr 29, 2019 Apr 29, 2019
Have you tried to Change the Version of your Programm, because of the contact with the Server you have some glitches :::)))
Sep 03, 2020 Sep 03, 2020
This happened to me when I had to restore files to my computer from a backup source after some repairs. The issue was that my Illustrator scratch disk had been set to my largest partition :E and after restoring my files my partition was listed as :F due to a temporary reserved partition from my backup taking :E upon reboot. I have had to relink a lot of things because of this and my scratch disk was no different. If this affects you, go to Edit -> Preferences -> Plug-Ins and Scratch Disks -> make sure that Primary is set to the right and/or largest partition in your hardrive. Best of Luck!
Aug 19, 2021 Aug 19, 2021
TNKS
Oct 18, 2021 Oct 18, 2021
I have found that embedding vector art into Indesign can be the culprit of an error that happens when exporting to pdf. I converted them to jpgs and - it worked. (Indesign saved fine with the vector art embedded - but errors occurred while exporting - or while trying to reduce the file size.)
Oct 19, 2021 Oct 19, 2021
Vector art in InDesign as such should not be an issue with InDesign. And converting it to JPG as general advice doesn't sound like good advice.
So exactly what did you place?
Exactly which file format?
How large was the filesize?
Mar 17, 2023 Mar 17, 2023
I can not save
