9 Replies Latest reply on May 12, 2012 12:31 AM by sasa1975sasa
    Retain bounding box dimensions after reflecting object
    Level 1
      Is there any way of retaining the dimensions of a bounding box after reflecting an object. E.g. if I create a rectangle and rotate it 45 degrees the bounding box is flush with the rectangle around its perimeter. However if I reflect the rectangle vertically at 90 degrees the bounding box is no longer flush with the rectangle and so I cannot scale the rectangle without losing its original dimensions.
      I've tried the reset bounding box option but it doesn't seem to work very well. Is there any way to reflect an object and retain the bounding box perimeter? Thanks.
