Show 10 replies
1. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
Harron K. Appleman Mar 17, 2009 8:10 AM (in response to bpylant)Can't get it to happen here.
Could be version-dependent. -
2. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
Gernot Hoffmann Mar 17, 2009 8:23 AM (in response to bpylant)Perhaps it happens because the document color
space is RGB.
How can I measure colors in the doc without
eyedropper ?
A rather strange tool - like a combination of
rule & hammer.
Best regards --Gernot Hoffmann -
3. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
Harron K. Appleman Mar 17, 2009 9:09 AM (in response to bpylant)>Perhaps it happens because the document color space is RGB.
Exactly right, Gernot.
I was able to replicate the 'problem' by using RGB mode. Eyedropper readings within the masked object are 19.61 / 39.61 / 59.61 / 0.39.
Differences between my readings and the OP's might be caused by different color space settings.
Or, it might be a version-dependent thing. -
4. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
bpylant Mar 17, 2009 10:03 AM (in response to bpylant)Sorry I didn't specify version/platform/color mode/color settings.
CS4
Repeatable on Mac and Windows
CMYK document mode (I never even tried with RGB, as I never work in RGB in Illustrator.)
The incorrect CMYK values are reported regardless of color settings (but different incorrect values result depending on what those settings are). -
5. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
Harron K. Appleman Mar 17, 2009 1:36 PM (in response to bpylant)My tests were conducted on AI 12 (CS2). -
6. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
Mike Sargent Mar 17, 2009 11:46 PM (in response to bpylant)Brian
Yes, totally repeatable here (CS4,CMYK, VIsta 32).
I have one strange difference - with every additional click of the eyedropper on the clipped object the actual fill colour of the clipped object changes. If I sample in isolation mode everything is normal. -
7. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
bpylant Mar 18, 2009 6:05 AM (in response to bpylant)OK, I've reported this as a bug (CS4, Mac and Windows). -
8. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
(Tim_Baigent) Mar 19, 2009 1:04 AM (in response to bpylant)I can't get this to "work". I.e. having followed the instructions carefully, I always get the correct value of c20 m40 y60 k00. -
9. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
bpylant Mar 19, 2009 5:33 AM (in response to bpylant)What version of Illustrator? It's repeatable in CS4 (Mac and Windows), and doesn't seem to have been present in CS2. But no one has posted about other versions. -
10. Re: Eyedropper Bug? (Objects in Clipping Masks Report Different CMYK values0
OldBob1957 Mar 19, 2009 6:16 AM (in response to bpylant)It does not happen when I try it in CS3 (Win). Values sample at c20, m40, y60 whether clipped or not.
