Show 11 replies
0. Re: Right Indent Tab
BranderChatfield Aug 11, 2008 8:23 AM (in response to BranderChatfield)For example:
Bent, Arthur Cleveland[Right Indent Tab]
28, 33, 37, 52, 71, 73, 77, 82, 96, 101, 105, 106, 107, 110, 130, 147, 152, 154
In a narrow column such as this:
Bent,
28, 33, 37, 52, 71,
105, 106, 107, 110,
130, 147, 152, 154
only "28, 33, 37, 52, 71," right-aligns and the rest are left-justified.
Anything quick and simple?
Bent,
28, 33, 37, 52, 71,
105, 106, 107, 110,
130, 147, 152, 154
2. Re: Right Indent Tab
(Dave_Saunders) Aug 11, 2008 9:31 AM (in response to BranderChatfield)Instead of using a right indent tab, use a regular tab, but setup the paragraph to be right-aligned.
Dave
Dave
3. Re: Right Indent Tab
BranderChatfield Aug 11, 2008 9:37 AM (in response to BranderChatfield)Yes, yet I need the first line of alpha-text to be left aligned, and the page numbers to be right-aligned.
4. Re: Right Indent Tab
MT.Freelance Aug 11, 2008 9:41 AM (in response to BranderChatfield)From your response, you've not tried Dave's suggestion. Give it a shot. It works.
5. Re: Right Indent Tab
BranderChatfield Aug 11, 2008 10:26 AM (in response to BranderChatfield)I have tried the recommendation, and the first line of alpha-text is right-aligned, not left-aligned as needed.
6. Re: Right Indent Tab
(Dave_Saunders) Aug 11, 2008 11:21 AM (in response to BranderChatfield)Then you didn't do it right. Either that, or you need to trash your preferences.
Dave
Dave
7. Re: Right Indent Tab
BranderChatfield Aug 11, 2008 12:00 PM (in response to BranderChatfield)Does this help any?
<br />
<br />
<a href="http://www.pixentral.com/show.php?picture=1E7gIVAzLspCpaOD1jN4UwrlAClX5E" /></a>
<img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1E7gIVAzLspCpaOD1jN4UwrlAClX5E_thumb.jpg" border="0" />
<br />
<br />The previous paragraphs are left-aligned with a right-indent tab before the page numbers. The "Bent" paragraph is right-aligned with a regular tab before the page numbers...
8. Re: Right Indent Tab
(Dave_Saunders) Aug 11, 2008 12:26 PM (in response to BranderChatfield)Ah, well that doesn't match the sample you gave in the message. If the tab is forced to the next line then you're out of luck.
Dave
Dave
9. Re: Right Indent Tab
MT.Freelance Aug 11, 2008 12:52 PM (in response to BranderChatfield)Option 1:
To force it to work, break the long name up with a Tab + Forced Line Break (Shift+Return) after the comma.
Option 2:
select all the text, with your existing tabs in place, and change to a table. Set all strokes to 0 point or none, right align the number column, left align the name column, set vertical cell alignment to top.
Option 3:
? anyone else have a suggestion?
HTH
-mt
Option 2:
Option 3:
HTH
-mt
10. Re: Right Indent Tab
BranderChatfield Aug 11, 2008 12:54 PM (in response to BranderChatfield)> Ah, well that doesn't match the sample you gave in the message. If the tab is forced to the next line then you're out of luck.
Yep, that was my guess. Thanks for the suggestions!
11. Re: Right Indent Tab
tobias.wantzen Aug 11, 2008 6:35 PM (in response to BranderChatfield)Daves suggestions work, but you have to change a bit:
Set the paragraph to be right-aligned und then use a right indent tab!
Personally I'd use an en space (or another white space) followed by the right indent tab between the topic and the page number. This garanties a bit of a distance between page numbers and topic.
Tobias
Tobias
