Locked
How do I import a .PDF into inDesign?
Nov 16, 2008 Nov 16, 2008
How do I import a .PDF into inDesign? Does anybody know how? I need to edit a book in inDesign that is a .PDF. So if anyone know how to do that please tell me.
How to
98.0K
http://recosoft.com/products/pdf2id/index.htm
Bob
Nov 17, 2008 Nov 17, 2008
In other words, InDesign cannot open PDF files by itself. PDF is a final format, it is not intended to be edited.
Keep in mind that even with that plugin unless the file is very basic you won't get anywhere near a perfect conversion.
Nov 18, 2008 Nov 18, 2008
There are other techniques for "ripping" a PDF to something like editable form, but most transform the file into Word format. There are better tools that will extract the content with minimal formatting, but that means the entire document has to be re-typeset.
As noted, PDF is just not meant to be edited and the workarounds are poor and clumsy at best.
A very wonky technique to make minor edits is to import and place the PDF in a new document, then painstakingly lay the corrections over the existing type. Yes, I've done it. No, I'm not proud of it. :P
╟ Word & InDesign to Kindle & EPUB: a Guide to Pro Results (Amazon) ╢
Guest
May 10, 2009 May 10, 2009
Seems strangely unsatisfying that two Adobe formats don't talk well to each other.  I'm working on a book that will have big chunks of polytonic Greek - these files are being produced on a Mac in Word.  I need to get these Mac-flavored files, full of Greek, into InDesign (with copyediting along the way).  Author and I thought that PDFs would be the way to go, because they hold the Greek steady.  Now I discover that PDF --> InDesign doesn't work.
What's my backup choice?  Sure, I can port the Mac-original into Word, and place that file, but that means I'll have to retype about 40 pages of Greek.  Slow, expensive, and likely to be error-prone.
What are alternatives?  Would a PostScript file format help? I'm not sure how those work.
Is there a conversion filter that handles Mac / PC (=Indesign) that will keep non-Latin fonts intact?   We're a v. small company - no way I can spring $300 for the plug-in mentioned above on this thread.  Hoping something has come along since 2002.
thx
Yard Camel
What do you mean PDF doesn't work? What happens when you try?
BTW, I hope you understand that PDFs must be placed into an InDesign layout, not opened? This leaves you with a static PDF that cannot be changed.
If you need changes you'll need to change the original file and re-create the PDF.
But I think I should point out that Mac/Windows is undoubtedly a red herring here. If you need to edit the Word file, using file>place, not copy/paste would be the best bet.
BTW, your opening remark shows a common misconception that all formats are interchangeable. This is simply untrue. There's a reason that the formats are different and PDF was never a format that was intended for editing. It's an end product much like a printed page.
Bob
Jan 31, 2021 Jan 31, 2021
weirdest thing is, InDesign uses PDF in the Clipboard...
So it is usedas intermediate,but if you fill the clipboard with the complete PDF contents,InDesign does not reflow the PDF, which seems very odd, don't you think.
In the 21stcentury one might expect InDesign capable of something Aldus (lateradobe) Pagemaker could do in 1986 (my first steps in DTP...)
Sorry, but I think your memory fails you.
PageMaker certainly didn't place PDF in 1986. PDF didn't exist until the mid-1990s and even then in the fading days of PageMaker, it never was able to place or import PDF.
InDesign may use some PDF constructs on the clipboard, and it can place PDF as-is, but it doesn't have a PDF to InDesign translator.
Others in this thread have pointed you to third party products that provide such functionality although in many cases, there is some “lossiness” since PDF is a superset of the InDesign imaging model.
- Dov Isaacs, former Adobe Principal Scientist (April 30, 1990 - May 30, 2021)
I agree with Bob that the whole Mac/PC thing is a red herring. Place the Word (or other text format) file, and use a substitute font if required because the original is a Mac-only format. Is there something sacred about the font? Are there no PC compatible fonts with the correct glyphs? What was the format before your friend made PDFs? Why do you think you'd need to re-type anything?
OpenType fonts are completely cross-platform compatible, and Windows-format TT fonts should work equally well in OS X, so you could ask your friend to use one of those on his end if you want to be sure there is no change in appearance.
Peter
Enthusiast ,
This has been cropping up quite a bit lately about opening PDFs in ID or some other app. People aren't grasping what a PDF is intended to be. Even odder is that people expect to open native ID files in word or vice versa and have it all work flawlessly as they go back and forth with edits. Granted this request or misunderstanding seems to be on the lower end of the design spectrum but still a bit puzzling to read about over and over again. ID is a page layout program, PS is for photo editing, AI for vector images and MS Word is a word processing. All discrete apps with specific functions inherent to them.
With PDFs, the fact that all of us have, at one time or another, opened PDFs in Acrobat or AI or PS to "fix" a PDF has probably led a fair number of people to think this is standard workflow and should work flawlessly every time. Tampering with a PDF is a kludge at best.
Guest
This all stems from the misconception that if you have a computer with Adobe software you are now a qualified Designer
Guest
Bob, Peter, grmg, many thanks for your very helpful comments.  Delighted mac/pc not relevant.  Will scratch that from list of herrings to chase.
Re PDFs - actually, I'm working in Acrobat (not just a finalized PDF), and Acrobat does of course allow editing of a sort; I'd concluded that since Adobe is willing to tolerate that degree of editing with its product, it should therefore tolerate moving its native format (*.pdf) into another of its own native formats (*.indd). I see that's a misconception.
This morning I tried all flavors I could find of getting my Acrobatted content into ID3, including copy/paste, place, and import (from the ID side); none was satisfactory.  Output from Acrobat to Word and then placing Word was fine for English but destroyed the Greek - not just wrong font, but complete gobbledygook and loss of all diacriticals.  Names of fonts don't matter for my purposes; the legibility of the English, and the legibility and tonic accuracy of the Greek do matter. Author of this project is not tech-savvy and is using old Greek system as well; nothing he or i can do to fix that.
Current plan is to request author to provide me his native files, which will be Mac files.  Am I understanding the Import dialog and your collecitve comments to suggest that with that file resident on my PC (and unopened), I can use the Place dialog, with "Show Options" selected, to get the Mac file into ID?
Chapeaux to those of you with constructive comments - hugely appreciated.
YC
It will depend on the format in which they were saved. ID has no import filters for the lesser word processors, but can use RTF or plain text which almost any word processor can save. The one area that may be a problem when changing fonts, and I only understand this at the basic level, is that some fonts will have special glyphs for your special tonal marks, while others will use combining forms to construct them from multiple glyphs, so you should try a sample and see.
Peter
Guest
Thanks much, Peter, will keep that in mind.  Trial /error seems to be my friend so far.
Thanks for your help.
YC
Jan 28, 2013 Jan 28, 2013
With Adobe's competitor, CorelDRAW, you can actually import a PDF into a project just by dragging it in... and the text will be editable.
I'm not condoning the use of Corel for anything else, however... I just happen to use it at work and am astounded at the simple nature of this feature. I've never seen another program able to edit PDF's so easily.
Valorous Hero ,
@x6
Several applications can open PDFs for editing, not just Corel. It isn't a simple thing, and I feel personally that it is unneeded in ID natively. But that is just my feeling. And there is a plug-in that one can purchase to do so though.
Mike
You can't edit a PDF in InDesign without some 3rd Party Tools.
You can place it in InDesign - and it behaves like an image placed - and you can draw and type over the areas you want to change - but it's not accurate.
You would need a 3rd party editor - like already menitoned.
Or Affinity Publisher can open and edit PDFs - but that is not part of the Adobe packages - it's different software.
