Problems with Flex Message Service
Avatar
Level 3
Hi all,
I'm woking fine with Flex Message Service, the Producers send
messages to destinations and subscribers receive those messages
fine.
But what if I want to use Java class to process the messages
a destination receives from a Producer? Is it possible? I would
like this Java class could (after processing) send messages to the
subscribers do that especific destinations.
Avatar
Level 2
I think you should use JMS to do this rather than the
messaging implementation in FDS. Using JMS, you would just create a
JMS client that was both a consumer and a producer. The JMS client
would use the same topic that your destination was configured to
use in Flex.
It may be possible to do it with the FDS messaging
implementation but it would be using java apis that I am pretty
sure we don't document and therefore they could potentially change.
I have seen some examples of sending messages into the Flex
messaging system from Java (the dashboard app in the samples does
this) but not where a java class is listening for messages. Hope
that helps.
Avatar
Level 3
I havent thought of that but sending messages from a java
class to Flex Message Service without listening to it would do the
job.. because the clients can "send messages" to a Java class using
RemoteObject! :) Problem solved. I'll take a look a dasgboard app
to learn how to do that. Thanks a lot aglosband.
