Show 16 replies
1. Re: Bypass "Missing Fonts"-box
(Robert_Tkaczyk) Feb 14, 2008 4:41 AM (in response to prodic)in Scripting you can use UserInteractionLevel
which version if ID you use ??
robin
www.adobescripts.com -
2. Re: Bypass "Missing Fonts"-box
prodic Feb 14, 2008 5:27 AM (in response to prodic)We're testing this on the CS2-version of Adobe InDesign.
Will a script provide the necessary solution and could you - or anyone else capable - provide me with an example?
We might also have to figure out a "auto-click"-solution to the dialog that appears in InDesign CS2 when opening a CS3-document.
Would a similar script take care of that as well? -
3. Re: Bypass "Missing Fonts"-box
prodic Feb 15, 2008 12:59 AM (in response to prodic)Found a script that's semi-useable.
However I'm looking for a script/feature/setting that sets "UserInteractionLevel" to never even when opening a file via explorer or via the open-dialog.
Can that be done?
//DESCRIPTION: Open Doc with No Warnings
if (app.version == 3) {
app.userInteractionLevel = UserInteractionLevels.neverInteract;
} else {
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
var myFile = File.openDialog("Choose InDesign document to open");
var myErr = "";
if (myFile != null) {
try {
app.open(myFile);
} catch (e) {
myErr = e;
app.userInteractionLevel = UserInteractionLevels.interactWithAll;
} else {
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
if (myErr != "") {
alert(myErr);
4. Re: Bypass "Missing Fonts"-box
Harbs. Feb 17, 2008 1:52 PM (in response to prodic)Just run this one-liner before you open your doc:
Just make sure you run this one afterwards...
Harbs -
5. Re: Bypass "Missing Fonts"-box
prodic Feb 18, 2008 12:03 AM (in response to prodic)Any chance of getting the:
made a default setting or similar?
Imagine you're opening an InDesign-file from a explorer-window/bridge or similar and don't want to see any dialog-screens at all. Is that possible? -
6. Re: Bypass "Missing Fonts"-box
Harbs. Feb 19, 2008 12:45 AM (in response to prodic)Once you set it to never interact, it will stay that way until you set
it to interact once more. Be very careful about using never interact
though. You might not get dialogs you want...
Harbs -
7. Re: Bypass "Missing Fonts"-box
prodic Feb 20, 2008 12:33 AM (in response to prodic)Sadly I can't seem to get the mentioned script to work.
Entered the
in a file and saved it as a .js-file and placed it in the scripting-folder.
See the script perfectly fine in InDesign and when I run the script nothing happens - as expected.
However when I drag an indd-file from eg. the desk top or a Explorer-window it still prompts me with dialogs(missing fonts etc.)
Have I done something wrong? Can't seem to pinpoint the exactly what might have gone wrong and why.
Kenneth -
8. Re: Bypass "Missing Fonts"-box
Harbs. Feb 20, 2008 3:48 PM (in response to prodic)What version of InDesign?
You can try these instead (but it shouldn't make a difference):
=UserInteractionLevels.NEVER_INTERACT;
=UserInteractionLevels.INTERACT_WITH_ALL;
If the never interact one still doesn't work, you might have something
resetting you user interaction level to interact...
Try running this script. It'll tell you the current interaction setting...
if(app.scriptPreferences.userInteractionLevel
==UserInteractionLevels.NEVER_INTERACT){
alert("No Dialogs!");
}else{
alert("Yes Dialogs!");
Harbs -
9. Re: Bypass "Missing Fonts"-box
P Spier Feb 20, 2008 3:56 PM (in response to prodic)Harbs,
I'm pretty ignorant about scripting and the ID object model, but does your script really affect anything beyond user interaction triggered via script?
Peter -
10. Re: Bypass "Missing Fonts"-box
Harbs. Feb 20, 2008 4:07 PM (in response to P Spier)Peter_Spier@adobeforums.com wrote:
> Harbs,
Yes. It affects all dialogs which pop up. (missing fonts, missing links,
color setting mismatches, etc.) Try it! ;)
Harbs -
11. Re: Bypass "Missing Fonts"-box
P Spier Feb 20, 2008 4:16 PM (in response to prodic)That's OK. I'll take your word for it. I've got enough problems this week without making trouble for myself by screwing up my settings accidentally. -
12. Re: Bypass "Missing Fonts"-box
prodic Feb 20, 2008 11:57 PM (in response to prodic)The version of InDesign is CS2(4.0.5)
Made a few sample scripts based on Harbs examples and the results are as follows.
When running this script:
the dialog-script displays "No Dialogs" as expected.
However when opening a file - with missing fonts - I still get prompted with a missing fonts-dialog.
the dialog-script displays "Yes Dialogs" as expected and I get prompted with the missing fonts-dialog.
Can't seem to figure out why the "no-script" still displays eg. a missing fonts-dialog. -
13. Re: Bypass "Missing Fonts"-box
Fred Goldman Feb 21, 2008 6:24 AM (in response to prodic)I could be wrong, but I always thought the userInteractionLevel
preference was specifically for dialog boxes that appear during scripts. -
14. Re: Bypass "Missing Fonts"-box
(Robert_Tkaczyk) Feb 24, 2008 3:56 PM (in response to prodic)Kenneth,
I think, you should use:
not NEVER_INTERACT and INTERACT_WITH_ALL
robin
15. Re: Bypass "Missing Fonts"-box
(Dave_Saunders) Feb 24, 2008 4:22 PM (in response to prodic)Robin,
Either works. The OMV uses the all caps forms but I prefer the other form.
Dave -
16. Re: Bypass "Missing Fonts"-box
prodic Feb 26, 2008 1:10 AM (in response to prodic)Sadly it didn't make a difference changing it into a non-caps.
Running the script appears to set the setting to "no dialogs" at least the "yes/no-script" provided by Harps displays "no dialogs", so hopefully it's correct.
But when opening an InDesign-file after running the script either through the Open-dialog or via drag from an Explorer-window it still prompts me with missing fonts-dialogs etc.
