Yes, you are right, if you do not "ARES" a PDF the barcode should still work but what you may see is that the Barcode gets encrypted. When the barcode is encrypted some of the space of the barcode is used up by the encryption process. So, this may cause a barcode that is filled to capacity perfectly fine in Acrobat to gray-out in Reader.
