0 Replies Latest reply: Jan 3, 2008 10:58 AM by glopezt RSS
    error database
    glopezt Community Member
      Help me please!!
      Hi, my problem is when i try to use robosource control the version control apper a message error that message is with fails to connect to the RoboSource Control database, i try to solve with reboot and modify some dll like i saw in a page (bsuuVersionControlServices.dll, bsvcMicrosoftSCC.dll, NetServerInterop.dll ), but i don't find why don't change nothing and my message is the same and this say:
      A network error occurred connecting to this database. Please check te server process is running, and that te server machine is addressable on the network.
      Do you want to use RoboSource Control offline using te tagging system? If you select Yes, your work will be saved locally and you can synchronize you work with the server when you reconnect to the network.
      But i need connect with the database by frist time.
      I'm working in roboinfo 5.0.2 and RoboSource Control 2.3.1006.0
      Thanks.
