Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Populate Text Field Based On Drop-Down List Selection
Avatar
Former Community Member
I'm trying to set up a form so that a text field will populate with default text (that could later be edited by the end user) based on a users previous drop-down selection.
For example:
The end user is putting together a proposal for a client and is able to choose the type of proposal or service from a drop-down list. Once the user makes a selection from the drop-down list a text field is populated with default text describing the service.
The only catch is that the end user would need to be able to edit the default text. An example would be if an individual purchased a car but all the specific features and/or accessories could be added into the default text as necessary based on the purchasers desired upgrades. The common or universal features of the car would, however, show up as the default text.
Would this scenario be possible through the use of XML? Any tips on how I can accomplish this would be much appreciated.
Avatar
I'm finding it a little difficult to grasp what you're trying to accomplish so here's what I think you're asking for: You have a form which has a drop down list and a text field. When the user selects an item in the drop down list, you would like the text field to be automatically populated with an initial (default) value describing the selected item which the user could then edit (in the text field) to suit their specific needs.
If that's correct, then you would need just a little bit of script on the drop down list's Change event which would determine the item selected by the user and would set the text field's value to that which pertains to the new selection.
Let's say the text field is named "TextField1" and that you've associated a value to each item in the drop down list so that the selection is easy to compare in order to determine which initial (default) value to set in the text field. In your drop down list's Change event, you could use the following script (in JavaScript):
var sNewSel = this.boundItem(xfa.event.newText);
switch (sNewSel)
case "1": // car purchase
TextField1.rawValue = "Basic features:\n- frame\n- wheels\n- glass";
break;
case "2": // other purchase
TextField1.rawValue = "Basic features..."
break;
default: // unknown value -- do nothing
break;
Here we see the use of the
xfa.event.newText property in order to retrieve the text associated to the item which was just selected in the drop down list. Then we use the
boundItem method of the drop down list (this) in order to retrieve the value that we associated to that item. Finally, we check the value and assign multi-lined values (note the "\n" characters in the strings which represent new lines) to our multi-lined TextField1 field's value.
To help illustrate this, I've create a small sample form which uses the code I described above with the added feature that the text field is disabled until the user makes a selection in the drop down list.
Stefan
Adobe Systems
Avatar
Hello Stefan,
I'm interested in the sample file you've created. Could you post it again?   I am also trying to populate textfields which are on different pages than the drop down lists, and have not succeeded. Can you help? Thanks.
thanks.
Nellie
Avatar
Level 1
Stefan
How do I get the PDF you devloped?
I need to see details of populating dropdown.
Can you also "extend" the dropdown to other dependant dropdowns?
--one DD detrmining another DD, which then fills a text field(s)..
-Allan
Avatar
Stefan,
I am not very literate in scripting, but am learning as I go, so hopefully this will make sense. I am trying to get the drop down to generate a message in a text field, and if drop down is left blank, no message is shown. I used your example above to get my drop down to generate a text field, but it is not working. My drop down list is named "Security Deposit" and the text field is "Security". Here is what I entered in the script editor using Javascript and Change:
var  (sNewSel=this.boundItem(xfa.event.newText);
switch  (sNewSel)
Security.rawValue
= " A security deposit has been paid to the Community. The deposit shall be applied to any damages done to Clubhouse or Community. If there are no damages, the payment will be returned to the Resident following inspection.";
break;
default://unknown value--do nothing
If you could please assist with this, I would really appreciate it!!
Thank you so much!
Avatar
Level 1
I am having difficulties getting this to work properly. I have a list box called [PURCHASE TYPE] and I want the selection to populate a text box.
Purchase Types
36 Month (Basic)
48 Month (Basic)
etc.
when selected I want the text box to read 36 MONTH BASIC, if that is the one they selected from the list. Does that make sense?
Avatar
Thanks so much Stefan! You were right on target and it works like a charm.
Avatar
Using Adobe LifeCycle Designer for Adobe 8 I'm trying to populate a text field with multiple entries from a drop down list. I managed to be able to populate the text field for a single selection from the drop down list but am having trouble getting it to allow multiple selections from the drop down list to populate the text field keeping all of the selections within it. When I click another selection from the drop down list the first entry that populated the text field is replaced by the new entry, I need it to maintain all entries entered...please help.
Avatar
Level 7
Your post is different form the Original Post and should be a separate post of it's own since it maybe lost and if the OP subscribes to this post by email, that person will be flooded with responses to your post.
In Acrobat, the Drop Down Box/List field does not support multiple selections only Combo List field does when that option is set for that field. Looking at the Drop Down List, I did not see an option to enable multiple item selection. Also LC D does not support the Acrobat JS "currentValueIndices" field property that is used to recover the multiple item selection array nor does it support the "getItemAt" field property that is used to get a selected entry from the combo list. So it appears this might not be possible.
For more information about Scripting in LC D see:
Scripting languages and resources (LiveCycle Designer 8.x)
http://www.adobe.com/cfusion/search/index.cfm?loc=en_us&term=livecycle+javascript
Avatar
I am new Adobe livecycle developer , my knowledge is Oracle and Sql , plSql . I want to design an adobe form, for which I have 2 drop down lists , one for all ministries , the other one is for all directorates which related to the selected ministry. The scenario is as follows:
The user will pick a ministry from the 1st drop down list, then for the 2nd dropdown, the list of all directorates that are belongs to the selected ministry should appear in order he can select the specified directory from the dropdown list. (no need for buttons).
I had tried the Stefan Camerons procedure in connecting a form to Db, and selecting specific record from a data base , the dropdown "Pick a Category" field is not working, also I had tried to copy his script into my form ,still is not working. Is there any method ? or maybe something I need to add to my script .
I am using adobe live cycle designer 7.1
Adobe reader is 7.0
the file is saved as pdf
data connection informations in the form are as follows :
1-DataConnection1.
Using OLEDB
database name is : Financial_DB_Forms (on the server)
OLEDB provider is :Microsoft OLEDB provider for SQL Server
Server : MOFNEO
Connecting string : Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=Financial_DB_Forms;Data Source=MOFNEO;Use Procedure for Prepare=1;Auto Translate=True;Packet Size=4096;Workstation ID=CPU-0900;Use Encryption for Data=False;Tag with column collation when possible=False
Table1 : Financial_Form_Ministry ( contains all ministries numbers and description)
2-DataConnection2. (same info. As above )
Table2 : Financial_Form_Directorate ( contains of all directorates for all ministries and description) .
Also can you please send me a telephone number and e-mail of any adobe developer that I can call him if I need any assistance .
Your help will be much appreciated,
Mariam Kadhimi
Tel : +973-39597575 (mobile)
Tel : +973-17575560 (Office)
Kingdom of Bahrain
Avatar
Stefan -
I had itially looked for a way to simply wrap text in a drop down list as I thought that would be the simplest way to do what the client requested (have a list of standard options to choose from but still enable custom entries).
Since I couldn't find a way to wrap my dropdown text, I tried to modify your sample from but I can't get it to work for me, and I'm not sure if it's the best option for what the client needs.
In addition to not being able to make the drop down affect the text box, how would I get the drop down to hide after exit? I will want to have this pairing repeat (for a total of 6 or 8 text boxes) and want to only print/see the text boxes, and not the drop downs after the text is entered.
My test doc is at www.scottsdaleaz.gov/Assets/documents/airport/TESTING-StipDropDownSelection.pdf
' Here's how I modified what you gave:
var bEnableTextField = true;
switch (sNewSel)
case "1": // Changes Require Approval Prior to Development Review
Stipulation1.rawValue = "Changes to the development plans anytime after airport staff has signed this
form requires additional airport approval of the change prior to development review
board hearing.";
break;
case "2": // FAA form 7460-1
Stipulation1.rawValue = "Developer must demonstrate that an FAA form 7460-1 was completed unless
exemptions apply."
break;
case "3": // Noise Disclosure
Stipulation1.rawValue = "Applicant must demonstrate aircraft noise and overflight activity disclosure to
proposed occupants."
break;
case "4": // Fuel Dispensing and Storage
Stipulation1.rawValue = "Fuel dispensing and storage proposed for development projects must have
specific documented airport review and approval. Storage and dispensing of fuel
must be in accordance with Airpark Rules and Regulations."
break;
case "5": // Significant Changes Required Additional Review
Stipulation1.rawValue = "Significant changes to this project require additional project review by airport
staff."
break;
case "6": // Approval Valid for 1 Year
Stipulation1.rawValue = "This approval is valid for up to one year from the date it was signed. Further
review is not required prior to final plans approval unless substantial revisions are
made to the development plans anytime after the date this form was approved."
break;
bEnableTextField = false;
break;
Thanks - This is the first time I've had to use LiveCycle instead of the basic forms tools.
Beckye Frey
Customer Relations Specialist
480-312-2743
bfrey@scottsdaleaz.gov
City of Scottsdale
Planning & Development Services Department
7447 E Indian School Road, Ste 105
Scottsdale, AZ 85251
Avatar
Is there any way that someone could explain it to a beginner?
Dropdown list > address info is based on list selection (address info is multiple lines "address, city, st, zip, phone"
So user is filling out a form, selects recipient, and the address info + phone populates on it's on (into a text box) based on the item selected in the drop down.
Avatar
Help.
Could you look at the following and see what I am missing? I have copied Stefan's example. I have modified it within the sample pdf that he posted and it works great. I have now tried to move it to my development form and I cannot get the textfield to populate with the drop down selection. I think it may be in naming convention, but not sure where or how to track down my problem. I have put them on the same subform, but that did not work.
Stan
----- form1.form2.BIP_Subform.EquipList::change: - (JavaScript
switch (sNewSel)
case "1": // AN
TextField10.rawValue = "Face Shield\nGoggles\nChemical Gloves\nAir Supplied Respirator\nChemical Green Suit\nChemical Boots";
break;
case "2": // BUO
break;
//I have 32 cases, but left them out here)
break;
if (bEnableTextField)
TextField10.access = "open"; // enable field
TextField10.caption.font.fill.color.value = "0,0,0"; // set caption to black
My textfield info is:
----- form1.form2.BIP_Subform.TextField10::change: - (JavaScript, client) --------------------------
Avatar
great stuff here.
Can this be applied to work on a second DROP DOWN LIST instead of a text field.
Simply put, I would like to populate a second drop down list based on chosen selections from a first drop down list.
thanks
Avatar
Hi Stefan,
I'm using you code that you posted first. How do I amend it so that the second text box is actually another drop down list?
Thanks, Justin
Avatar
Hi Redcoat,
Were you able to figure out how to make the second list a drop down menu?
Thanks, Justin
Avatar
Dear Stefan
Ref. you post above, I am trying to do a similar thing but no vain. Would you please help me?
I have a form where I have drop down list menu named as "Country" it shows names of many countries then I have another drop down list box with the name "cities" which has name of many cities....
In both of the above fields I have manually entered the names of the countries and cities respectively in the designer.
what I want is that when i select the specific country then all cities related to the country only show up in the "cities" drop down list box?
Is this possible in forms? I am using Life Cylce ES 8.2
please advise
Asim
Avatar
I'm using Stefan's original example which is exactly what I am looking for but I'm having trouble moving the text field to a different page than the drop down. I want the user to select from the dropdown on page 1 and have that populate text fields on other pages. Is there additional script involved?
Avatar
I'm also trying to have it populate multiple text fields across multiple pages.
Avatar
Greetings,
I've figured out how to string together different text and numeric fields into a single text field. My question is - is there any way i can have the results sent as a text message to a mobile phone? I simply want to send simple text to a mobile phone number.
Any ideas?
