Hi Jenniab
As MergeThis pointed out, you are talking about output files
here. So I'm afraid that there is no way past that. However, I'm
also aware that sometimes folks want to use Source Control as a
mechanism for the installer to grab the files needed for the build.
So I can see where you may have a need to store them there. If this
is the case, I may have a solution to offer.
Use the built in publisher! Just define a different folder
where your Subversion files are stored. Then when you
Publish your output files from the WebHelp output folder to
the other one, the Subversion files won't be deleted. All that will
happen is that RoboHelp will dutifully replace the files that
should be replaced.
Just a thought... Rick
