Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Convert Dynamic XDP to PDF
Avatar
Former Community Member
Can PDF Generator programatically (Java) convert a dynamic XDP form that has been filled out by a user into a static PDF?
Bob
Avatar
Hi Bob,
Did you find a solution for your problem?
Can anybody know any solution to convert dynamic form to static?
Thank you.
asiye.aydin@gmail.com
Avatar
Is it possible to access interactive PDF through windows logon( windows may have multiple user accounts). On one particular account , if the user enter login credentials--(if valid)--then he should access the paricular pdf( fill & submit vice versa.).
Any useful information would be appriciated.
Ramesh
Avatar
Level 2
You can try extrating the xml data from the XDP form and re-render the XDP form with the extracted xml data plus a static PDFFormRenderSpec. Make sure the PDFFormRenderSpec is set to RenderAtClient as false.
