I'm puzzled. I have a project that has suddenly decided to
name the mergedProjects folder "mergedprojects" in the generated
output. Since our help lives on a unix server, the change in case
is a problem. All of our projects, including this one, have
consistently generated the "mergedProjects" folder. Until now, when
this particular one has gone rogue. The change happened when I
generated output via the command line. Now I get the lowercase
"mergedprojects" folder even when I generate from the UI.
Something has changed, but what?
The other projects are fine, even though they went
through the same process. Knowing that this can occur, we can
manually fix the filename, but I'd really rather cure the problem
if I can. Any ideas? In the meantime, I am going to grab another
copy of the project and see if the problem is some strange anomaly
that has perhaps cured itself. How's that for wishful thinking?
G
