Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Parsing XML with Adobe Javascript
Avatar
Former Community Member
I am using the standard SQL QPAC to fetch list data from a database. As we already know, the standard SQL APAC cannot retrieve multiple rows, but I use the "FOR XML AUTO" in my SQL statement so that all rows are returned in XML format.
I now only need to parse the XML and put the items into my drop-down list.
Does anyone have script samples that can parse XML from within LiveCycle? You would think that the capability exists since the product is based on xml/xfa.
Duncan Campbell
Xcellerate IT
Avatar
Are you looking to parse it in a script qpac? If so then you can store the XML in an xml process variable, then use getProcessDataValue() from PATExecutionContext to retrieve a Document object for the DOM.
Chris
Adobe Enterprise Developer Support
Avatar
Chris,
Can you please point me towards the proper documentation of this stuff: getProcessDataValue() and PATExecutionContext?
I searched high and low for anything on them, and found nothing.
Duncan
Avatar
Sure, take a look at the JavaDocs that come with the LiveCycle Workflow SDK. Under Documentation/api/LiveCycle_Workflow_SDK_API_Reference.
FYI, in a script QPAC the PATExecutionContext is an implicit object accessed under patExecContext. In a custom QPAC it is a parameter to the execute method.
Chris
Avatar
Chris,
I tried putting the following XML into an xml variable, but I received an error instead:
12Otis3
Do you know precisely how to perhaps get the proper XML results from a SELECT statement that will go into an XML variable? I used
"SELECT CLIENT_NAME as item from clients as list ORDER BY CLIENT_NAME FOR XML auto, elements" and I'm using a standard SQL QPAC to return the XML results.
Once I get the XML properly into the XML variable, I will try to use the getProcessDataValue() method.
Duncan Campbell
Avatar
Level 9
Hi Duncan
If you have problems doing it that way, you can also download our SQLPlus QPAC, which will allow you to iterate over a result set and format the output in a number of ways, including a simple comma separated list. You can then use a simple script in the form to unpack the list into a dropdown.
Howard
http://www.avoka.com
Avatar
Duncan,
It may be just as simple to write a QPAC that does the query and returns a comma-delimited list as a string. You could then have the form take that string as a hidden field and parse it into the drop-down list in the same method that Workflow provides the submission choice drop-down list.
Clifton
Avatar
Wow guys,
You all provided very good solutions that I may try someday. I really mean that, but my intention with this particular workflow is to use only the tools I get out of the box. I really want to know the base components well so that I get a full understanding of what the provided QPACs can and cannot do.
That way I get to learn about how to use some of the loosly documented methods like getProcessDataValue(). Forgive my ignorance, can anyone please tell me how I am to script a call to this method, if you have used it already?
Thanks heaps,
Duncan Campbell
Avatar
You're getting an error because that XML is not well formed so a DOM cannot be built for it. There needs to be a root node, something like enclosing all that in ....
I'm attaching a simple workflow I exported. It sets the value of an XML variable, and then using a script QPAC to call getProcessDataValue() and retrieve a Document object that can be used to parse the XML.
Chris
Avatar
Duncan,
Did you ever have any luck with this? Any additional pointers?
I think I am going to do something similar. I am planning on sending in an email that contains XML data of just 9 fields (collected from a form online - outside of the LC system and then using the Email Receiver to collect the email. The email body is the XML data). So, I need to parse this out and set the elements to variables to populate my PDF form.
If I get something working, I will try to post back.
Jennifer
Avatar
Level 9
Hi Jennifer
You may be able to get a fair bit of it done just using the SetValue QPAC. I think (although I'm not sure) that you can use expressions like:
/process_data/myxml/rootnode/row[2]/firstname
So as long as you know the number of rows you want to process, you may be able to get by.
Let us know how you get on.
howard
Avatar
Hello,
Actually, I ended up doing something a little different.
Since I only have 9 fields to get parse, I did use the Set Value QPAC, but I used substring-after and substring-before functions. I had to do this in two different Set Value QPACS, I couldn't group them together for some reason. So, the body of the email contains my XML data and I set the body to a variables and then parse it out in those 2 Set Value QPACS.
It works great!
-Jennifer
Avatar
I could not able to retrieve the remote xml file(which means from server to another server) in Mozilla Firefox and some times inn IE also.
I found the Error: "Error: uncaught exception: Permission denied to call method XMLDocument.load"
please help me in this area if you find or knew.
Thank you
Avatar
Level 9
Hi Thiru
It's a little difficult to work out what you're doing from your posting.
I suspect it may be that you're trying to load a document in Reader. This is not allowed, you must use Acrobat. (Or reader enable the form.)
Howard
