Problem using executeScript service
Avatar
Level 8
Level 8
Hi all,
I have been trying to use the executeScript service for ES, however the help documentation does not seem to be accurate. Does anyone know how I can access process variables and other interesting stuff using the executeScript service?
Sincerely
Kim Christensen
Avatar
Former Community Member
Hi Kim,
I assume you're looking for the "get" and "set" methods?
Here's a quick sample from a executeScript service
String inString = patExecContext.getProcessDataStringValue("/process_data/@stringValueOfSignatoryIdentities");
String outstring = inString.replace("&", "&");
System.out.println("***** String: " + outstring );
patExecContext.setProcessDataStringValue("/process_data/@stringValueOfSignatoryIdentities", outstring);
Lee.
Avatar
Level 8
Level 8
Hi again,
That sounds great, I will try you suggestion out right away. But I would also like to have some documentation of what other methods/functions LiveCycle ES provides for handling scripts.
Do you have any refernces?
Thank you again
Sincerely
Kim Christensen
Avatar
Level 8
Level 8
Hi again Lee,
The code sample you provided works great, thanks man. Still I would like to see some documentation for the functions.
Thanks again
Sincerely
Kim Christensen
Avatar
You can find all of the documentation for LiveCycle products under: http://www.adobe.com/support/documentation/en/livecycle/. Click on the "Develop" tab and then scroll all the way to the bottom and you'll find a nice 31MB file that contains everything you need.
For your forms development I would also recommend checking out http://www.adobe.com/devnet/acrobat/javascript.html.
Avatar
how to call another LiveCycle process from executeScript
Avatar
Why would you call it from execute script ....why not simply drag the service onto your process map?
