I have a form that imports data using the import data service. And then passing it thru reader extensions but the typed data by the user is not getting saved.
Check the bindings on the form that your user is filling out. They should be set to normal if you are not using a data schema or should be set to a node in the schema if you are using a data schema.
I will need to look at the form and data ...can you post it somewhere so I can get it? Or if you post your email I will send you a message where you can email it to me.
