ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
Avatar
Former Community Member
We've created a process with an input parameter (String) and an output parameter. There is only one "Query Single Row" node. The SQL we've put has been tested successfully. But when the client Java program invokes it, it got the exception of "ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable"
Avatar
The full trace is:
Caused by: ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker.java:311)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:98)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:134)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:44)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:326)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew(EjbTransactionCMTAdapterBean.java:272)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_caf58c4f.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:143)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:93)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:47)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:113)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:102)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiver.java:298)
at com.adobe.idp.dsc.provider.impl.ejb.receiver.EjbReceiverBean.invoke(EjbReceiverBean.java:146)
at com.adobe.idp.dsc.provider.impl.ejb.receiver.EJSRemoteStatelessInvocation_b542628e.invoke(Unknown Source)
at com.adobe.idp.dsc.provider.impl.ejb.receiver._EJSRemoteStatelessInvocation_b542628e_Tie.invoke(_EJSRemoteStatelessInvocation_b542628e_Tie.java:161)
at com.adobe.idp.dsc.provider.impl.ejb.receiver._EJSRemoteStatelessInvocation_b542628e_Tie._invoke(_EJSRemoteStatelessInvocation_b542628e_Tie.java:88)
at com.ibm.CORBA.iiop.ServerDelegate.dispatchInvokeHandler(ServerDelegate.java:613)
at com.ibm.CORBA.iiop.ServerDelegate.dispatch(ServerDelegate.java:466)
at com.ibm.rmi.iiop.ORB.process(ORB.java:503)
at com.ibm.CORBA.iiop.ORB.process(ORB.java:1553)
at com.ibm.rmi.iiop.Connection.respondTo(Connection.java:2680)
at com.ibm.rmi.iiop.Connection.doWork(Connection.java:2554)
at com.ibm.rmi.iiop.WorkUnitImpl.doWork(WorkUnitImpl.java:62)
at com.ibm.ejs.oa.pool.PooledThread.run(ThreadPool.java:118)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)
Caused by: java.lang.RuntimeException: enlist: caught Exception
at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:621)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker.java:261)
... 32 more
at com.adobe.idp.dsc.provider.impl.base.AbstractResponseHolder.handleException(AbstractResponseHolder.java:136)
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.doSend(EjbMessageDispatcher.java:137)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:57)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at adobe.lc.sdk.InvokeForm7ProcessUsingEJB.invokeMyService(InvokeForm7ProcessUsingEJB.java:69)
at adobe.lc.sdk.InvokeForm7ProcessUsingEJB.main(InvokeForm7ProcessUsingEJB.java:42)
Avatar
Level 10
What is your output parameter type?
Can you post your java code where you call the process?
Jasmin
Avatar
I got this Exception when I was trying to convert the BarCode into XML. Here is my client Program.
import java.io.File;
import java.io.*;
import java.io.FileInputStream;
import java.util.Iterator;
import java.util.List;
import java.util.Properties;
import javax.xml.transform.*;
import javax.xml.transform.dom.DOMSource;
import javax.xml.transform.stream.StreamResult;
import com.adobe.livecycle.barcodedforms.CharSet;
import com.adobe.livecycle.barcodedforms.Delimiter ;
import com.adobe.livecycle.barcodedforms.XMLFormat ;
import com.adobe.idp.Document;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.livecycle.barcodedforms.client.*;
public class Testmain {
public static void main(String[] args) {
try
//Set LiveCycle ES service connection properties
Properties ConnectionProps = new Properties();
ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "t3://rndvipdev02:80");
ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","EJB");
ConnectionProps.setProperty("DSC_SERVER_TYPE", "Weblogic");
ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
//Create a ServiceClientFactory object
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
BarcodedFormsServiceClient barClient = new BarcodedFormsServiceClient(myFactory);
//Specify a PDF document to convert to a XDP file
FileInputStream fileInputStream = new FileInputStream("D:\\abc\\barcode.pdf");
Document inDoc = new Document (fileInputStream);
java.lang.Boolean myFalse = new java.lang.Boolean(false);
java.lang.Boolean myTrue = new java.lang.Boolean(true);
//Decode barcoded form data
org.w3c.dom.Document decodeXML = barClient.decode(
inDoc,
myTrue,
myFalse,
myFalse,
myFalse,
myFalse,
myFalse,
myFalse,
myFalse,
CharSet.UTF_8);
//Convert the decoded data to XDP data
List extractedData = barClient.extractToXML(
decodeXML,
Delimiter.Tab,
Delimiter.Tab,
XMLFormat.XDP);
//Create an Iterator object and iterate through
//the List object
Iterator iter = extractedData.iterator();
int i = 0 ;
while (iter.hasNext()) {
//Get the org.w3c.dom.Document object in each element
org.w3c.dom.Document myDom = (org.w3c.dom.Document)iter.next();
//Convert the org.w3c.dom.Document object to a
//com.adobe.idp.Document object
com.adobe.idp.Document myDocument = convertDOM(decodeXML);
//Save the XML data to extractedData.xml
File myFile = new File("D:\\abc\\extractedData"+i+".xml");
myDocument.copyToFile(myFile);
i++;
catch(Exception e)
e.printStackTrace();
//This user-defined method converts an org.w3c.dom.Document to a
public static com.adobe.idp.Document convertDOM(org.w3c.dom.Document doc)
byte[] mybytes = null ;
com.adobe.idp.Document myDocument = null;
try
//Create a Java Transformer object
TransformerFactory transFact = TransformerFactory.newInstance();
Transformer transForm = transFact.newTransformer();
//Create a Java ByteArrayOutputStream object
ByteArrayOutputStream myOutStream = new ByteArrayOutputStream();
//Create a Java Source object
Source myInput = new DOMSource(doc);
//Create a Java Result object
Result myOutput = new StreamResult(myOutStream);
//Populate the Java ByteArrayOutputStream object
transForm.transform(myInput,myOutput);
//Get the size of the ByteArrayOutputStream buffer
int myByteSize = myOutStream.size();
//Allocate myByteSize to the byte array
mybytes = new byte[myByteSize];
//Copy the content to the byte array
mybytes = myOutStream.toByteArray();
com.adobe.idp.Document myDoc = new com.adobe.idp.Document(mybytes);
myDocument = myDoc ;
catch(Exception ee)
ee.printStackTrace();
return myDocument;
Here is the Exception StackTrace
Caused by: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:210)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:336)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(EjbTransactionCMTAdapterBean.java:212)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapter_z73hg_ELOImpl.doSupports(EjbTransactionCMTAdapter_z73hg_ELOImpl.java:145)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:104)
at com.adobe.idp.dsc.provider.impl.ejb.receiver.EjbReceiverBean.invoke(EjbReceiverBean.java:151)
at com.adobe.idp.dsc.provider.impl.ejb.receiver.Invocation_fpvhue_EOImpl.invoke(Invocation_fpvhue_EOImpl.java:61)
at com.adobe.idp.dsc.provider.impl.ejb.receiver.Invocation_fpvhue_EOImpl_WLSkel.invoke(ILweblogic.rmi.spi.InboundRequest;Lweblogic.rmi.spi.OutboundResponse;Ljava.lang.Object;)Lweblogic.rmi.spi.OutboundResponse;(Unknown Source)
at weblogic.rmi.internal.BasicServerRef.invoke(BasicServerRef.java:589)
at weblogic.rmi.cluster.ClusterableServerRef.invoke(ClusterableServerRef.java:224)
at weblogic.rmi.internal.BasicServerRef$1.run(BasicServerRef.java:479)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:363)
at weblogic.security.service.SecurityManager.runAs(Lweblogic.security.acl.internal.AuthenticatedSubject;Lweblogic.security.acl.internal.AuthenticatedSubject;Ljava.security.PrivilegedExceptionAction;)Ljava.lang.Object;(Unknown Source)
at weblogic.rmi.internal.BasicServerRef.handleRequest(BasicServerRef.java:475)
at weblogic.rmi.internal.BasicServerRef.access$300(BasicServerRef.java:59)
at weblogic.rmi.internal.BasicServerRef$BasicExecuteRequest.run(BasicServerRef.java:1016)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:200)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:172)
Caused by: com.adobe.barcodedforms.decoder.DecodingException null: com.adobe.barcodedforms.decoder.processors.DataProcessorException: com.adobe.barcodedforms.decoder.processors.DataProcessorException
at com.adobe.livecycle.barcodedforms.BarcodedFormsService.decode(BarcodedFormsService.java:297)
at j
Avatar
Hi David,
Did you ever get this problem solved? If so, could you please explain how did you get it solved.
Han Dao
Avatar
Level 10
Try Changing the componentId and version in the component.xml and try.
