Error ALC-WKS-007-043 When trying to complete form.
Avatar
Level 2
I'm new to LiveCycle just trying to trial LiveCycle 8 ES.
But when I try to complete the "Mortgage Application" form in workspace, from example "Creating Your First Application".
I get "An error occurred submitting the form (task 5, form {1}). (ALC-WKS-007-043)".
Does anyone know why?
I've tried various things with no luck, but I've noticed when creating the process that the Form Data Mappings for Loan Officer and Bank Manager don't have "Output form data - (Variable)" it has "Output form data - (Variable)" instead.
Avatar
Level 10
Can you copy the error that's being written in the server.log.
Also I didn't understand your last sentence "but I've noticed when creating the process that the Form Data Mappings for Loan Officer and Bank Manager don't have "Output form data - (Variable)" it has "Output form data - (Variable)" instead."
Jasmin
Avatar
Level 2
In regards to my last comment, I meant to say:
"Output form data - (Variable)" it has "Output form data - (X-path)" instead. See page 40 in Creating Your First LiveCycle ES Application.pdf
Here is the latest server logs.
The first error is from the latest log file.
The second error is from the previous days log file
This error is all through the log file.
2007-08-09 00:00:01,388 INFO [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Trying to reconnect to JMS provider
2007-08-09 00:00:01,419 ERROR [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Reconnect failed: JMS provider failure detected:
javax.naming.NameNotFoundException: XAConnectionFactory
at org.jboss.ha.jndi.TreeHead.lookup(TreeHead.java:223)
at org.jboss.ha.jndi.HAJNDI.lookup(HAJNDI.java:134)
at sun.reflect.GeneratedMethodAccessor347.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.jboss.ha.framework.interfaces.HARMIClient.invoke(HARMIClient.java:229)
at $Proxy290.lookup(Unknown Source)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:610)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:572)
at javax.naming.InitialContext.lookup(InitialContext.java:351)
at org.jboss.ejb.plugins.jms.DLQHandler.createService(DLQHandler.java:151)
at org.jboss.system.ServiceMBeanSupport.jbossInternalCreate(ServiceMBeanSupport.java:245)
at org.jboss.system.ServiceMBeanSupport.create(ServiceMBeanSupport.java:173)
at org.jboss.ejb.plugins.jms.JMSContainerInvoker.innerStartDelivery(JMSContainerInvoker.java:605)
at org.jboss.ejb.plugins.jms.JMSContainerInvoker$ExceptionListenerImpl.run(JMSContainerInvoker.java:1471)
at java.lang.Thread.run(Thread.java:595)
Another error the day before
2007-08-08 16:54:08,714 INFO [org.jboss.naming.NamingService] Started jndi bootstrap jnpPort=1099, rmiPort=1098, backlog=50, bindAddress=/0.0.0.0, Client SocketFactory=null, Server SocketFactory=org.jboss.net.sockets.DefaultSocketFactory@ad093076
2007-08-08 16:54:16,723 INFO [org.jboss.jmx.adaptor.snmp.agent.SnmpAgentService] SNMP agent going active
2007-08-08 16:54:17,532 INFO [org.jboss.ha.framework.interfaces.HAPartition.DefaultPartition] Initializing
2007-08-08 16:54:17,550 INFO [STDOUT]
GMS: address is cmri-adobelc:1065 (additional data: 17 bytes)
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.interfaces.HAPartition.DefaultPartition] Number of cluster members: 1
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.interfaces.HAPartition.DefaultPartition] Other members: 0
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.interfaces.HAPartition.DefaultPartition] Fetching state (will wait for 30000 milliseconds):
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.interfaces.HAPartition.lifecycle.DefaultPartition] New cluster view for partition DefaultPartition (id: 0, delta: 0) : [192.168.0.23:1099]
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.server.DistributedReplicantManagerImpl.DefaultPartition] I am (null) received membershipChanged event:
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.server.DistributedReplicantManagerImpl.DefaultPartition] Dead members: 0 ([])
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.server.DistributedReplicantManagerImpl.DefaultPartition] New Members : 0 ([])
2007-08-08 16:54:19,754 INFO [org.jboss.ha.framework.server.DistributedReplicantManagerImpl.DefaultPartition] All Members : 1 ([192.168.0.23:1099])
2007-08-08 16:54:19,789 INFO [org.jboss.ha.jndi.HANamingService] Started ha-jndi bootstrap jnpPort=1100, backlog=50, bindAddress=/0.0.0.0
2007-08-08 16:54:22,734 INFO [jacorb.orb] ORB run
2007-08-08 16:54:23,113 INFO [org.jboss.iiop.CorbaNamingService] Naming: [IOR:000000000000002B49444C3A6F6D672E6F72672F436F734E616D696E672F4E616D696E67436F6E746578744578743A312E3000000000000200000000000000D8000102000000000D3139322E3136382E302E323300000DC8000000114A426F73732F4E616D696E672F726F6F74000000000000050000000000000008000000004A414300000000010000001C00000000000100010000000105010001000101090000000105010001000000210000005000000000000000010000000000000024000000200000007E00000000000000010000000D3139322E3136382E302E323300000DC9000000000000000000000000000000000000000000000000000000000000002000000004000000000000001F0000000400000003000000010000002000000000000000020000002000000004000000000000001F0000000400000003]
2007-08-08 16:54:23,251 INFO [org.jboss.tm.iiop.CorbaTransactionService] TransactionFactory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
2007-08-08 16:54:25,008 INFO [org.jboss.mail.MailService] Mail Service bound to java:/Mail
2007-08-08 16:54:25,421 INFO [org.jboss.cache.TreeCache] setting cluster properties from xml to: UDP(ip_mcast=false;ip_ttl=8;loopback=false;mcast_addr=230.1.2.7;mcast_port=45577;mcast_recv_buf_size=80000;mcast_send_buf_size=150000;ucast_recv_buf_size=80000;ucast_send_buf_size=150000):PING(down_thread=false;num_initial_members=3;timeout=2000;up_thread=false):MERGE2(max_interval=20000;min_interval=10000):FD_SOCK:VERIFY_SUSPECT(down_thread=false;timeout=1500;up_thread=false):pbcast.NAKACK(down_thread=false;gc_lag=50;max_xmit_size=8192;retransmit_timeout=600,1200,2400,4800;up_thread=false):UNICAST(down_thread=false;min_threshold=10;timeout=600,1200,2400;window_size=100):pbcast.STABLE(desired_avg_gossip=20000;down_thread=false;up_thread=false):FRAG(down_thread=false;frag_size=8192;up_thread=false):pbcast.GMS(join_retry_timeout=2000;join_timeout=5000;print_local_addr=true;shun=true):pbcast.STATE_TRANSFER(down_thread=true;up_thread=true)
2007-08-08 16:54:25,438 INFO [org.jboss.cache.TreeCache] interceptor chain is:
class org.jboss.cache.interceptors.CallInterceptor
class org.jboss.cache.interceptors.LockInterceptor
class org.jboss.cache.interceptors.UnlockInterceptor
class org.jboss.cache.interceptors.ReplicationInterceptor
2007-08-08 16:54:25,438 INFO [org.jboss.cache.TreeCache] cache mode is REPL_ASYNC
2007-08-08 16:54:25,455 INFO [STDOUT]
GMS: address is cmri-adobelc:1070
2007-08-08 16:54:27,884 INFO [org.jboss.cache.TreeCache] viewAccepted(): new members: [cmri-adobelc:1070]
2007-08-08 16:54:27,884 INFO [org.jboss.cache.TreeCache] new cache is null (maybe first member in cluster)
2007-08-08 16:54:27,936 INFO [org.jboss.cache.TreeCache] state could not be retrieved (must be first member in group)
2007-08-08 16:54:28,762 INFO [org.apache.catalina.startup.Embedded] Catalina naming disabled
2007-08-08 16:54:29,365 INFO [org.apache.coyote.http11.Http11Protocol] Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080
2007-08-08 16:54:29,365 INFO [org.apache.catalina.startup.Catalina] Initialization processed in 568 ms
2007-08-08 16:54:29,365 INFO [org.jboss.web.tomcat.tc5.StandardService] Starting service jboss.web
Avatar
Level 2
2007-08-08 16:54:29,365 INFO [org.apache.catalina.core.StandardEngine] Starting Servlet Engine: Apache Tomcat/5.5
2007-08-08 16:54:29,400 INFO [org.apache.catalina.core.StandardHost] XML validation disabled
2007-08-08 16:54:29,417 INFO [org.apache.catalina.startup.Catalina] Server startup in 52 ms
2007-08-08 16:54:30,020 INFO [org.jboss.web.tomcat.tc5.TomcatDeployer] deploy, ctxPath=/invoker, warUrl=.../deploy/httpha-invoker.sar/invoker.war/
2007-08-08 16:54:31,329 INFO [org.apache.catalina.loader.WebappLoader] Dual registration of jndi stream handler: factory already defined
2007-08-08 16:54:32,259 INFO [org.jboss.web.tomcat.tc5.TomcatDeployer] deploy, ctxPath=/ws4ee, warUrl=.../tmp/deploy/tmp25916jboss-ws4ee-exp.war/
2007-08-08 16:54:32,448 INFO [org.jboss.web.tomcat.tc5.TomcatDeployer] deploy, ctxPath=/, warUrl=.../deploy/jbossweb-tomcat55.sar/ROOT.war/
2007-08-08 16:54:33,000 INFO [org.jboss.web.tomcat.tc5.TomcatDeployer] deploy, ctxPath=/juddi, warUrl=.../deploy/juddi-service.sar/juddiws.war/
2007-08-08 16:54:33,396 INFO [org.apache.juddi.registry.RegistryServlet] Loading jUDDI configuration.
2007-08-08 16:54:33,396 INFO [org.apache.juddi.registry.RegistryServlet] Resources loaded from: /WEB-INF/juddi.properties
2007-08-08 16:54:33,396 INFO [org.apache.juddi.registry.RegistryServlet] Initializing jUDDI components.
2007-08-08 16:54:33,861 INFO [org.jboss.web.tomcat.tc5.TomcatDeployer] deploy, ctxPath=/web-console, warUrl=.../deploy/management/console-mgr.sar/web-console.war/
2007-08-08 16:54:34,929 INFO [org.jboss.web.tomcat.tc5.TomcatDeployer] deploy, ctxPath=/jbossmq-httpil, warUrl=.../deploy-hasingleton/jms/jbossmq-httpil.sar/jbossmq-httpil.war/
2007-08-08 16:54:35,686 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-ha-local-jdbc.rar
2007-08-08 16:54:35,962 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-ha-xa-jdbc.rar
2007-08-08 16:54:36,289 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-local-jdbc.rar
2007-08-08 16:54:36,582 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-xa-jdbc.rar
2007-08-08 16:54:36,737 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jms/jms-ra.rar
2007-08-08 16:54:36,789 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/mail-ra.rar
2007-08-08 16:54:37,650 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=IDP_DS' to JNDI name 'java:IDP_DS'
2007-08-08 16:54:37,650 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=com.celequest.metadata.metaDatasource' to JNDI name 'java:com.celequest.metadata.metaDatasource'
2007-08-08 16:54:38,012 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name 'java:JmsXA'
2007-08-08 16:54:38,012 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=ConnectionFactoryBinding,name=adobe_JmsQueueXA' to JNDI name 'java:adobe_JmsQueueXA'
2007-08-08 16:54:38,149 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jc
Avatar
Level 2
Caused by: java.sql.SQLException: Access denied for user 'adobe'@'localhost' (using password: YES)<br /> at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2928)<br /> at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:771)<br /> at com.mysql.jdbc.MysqlIO.secureAuth411(MysqlIO.java:3649)<br /> at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1176)<br /> at com.mysql.jdbc.Connection.createNewIO(Connection.java:2558)<br /> at com.mysql.jdbc.Connection.<init>(Connection.java:1485)<br /> at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:266)<br /> at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:154)<br /> ... 122 more<br />****
Avatar
Level 10
As for your question concerning "Output form data - (Variable)" vs "Output form data - (X-path)". There are two ways you can pick the variable that contains the value for output form data: Variable or XPath.
Variable will give you a drop down that lists all the variable which you can select from. In this case, I would recommend using that.
XPath, will allow you to enter the XPath expression to the variable that will contain the data. You can also use the XPath builder to figure the XPath expression.
Both methods are valid.
XPath might seem a bit more complicated in that case , but it's very useful at time, since it allows you to drill down into attributes and nodes of a complex objects.
Now for your error. Can you just try to load you form from workspace and send me the last error in the log.
Jasmin
Avatar
Level 2
Thanks Jasmin,
It looks like my LiveCycle Server need to be reinstalled. I can't even get to my Workspace, it looks like a whole bunch of services have failed.
Thanks again for your help, and if I have help after Reinstall I'll let you know.
Avatar
Former Community Member
I got 2 exceptions during runtime I can not understand,
(JMS ERROR and DATABASE ADOBE USER ERROR)
but my Forms ES component renders PDFs successfully.
It seems to be ok.
Thanks in advance!
Gabriele
// THE FRIST
2007-10-16 15:31:51,141 INFO [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Trying to reconnect to JMS provider
2007-10-16 15:31:51,141 ERROR [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Reconnect failed: JMS provider failure detected:
at sun.reflect.GeneratedMethodAccessor234.invoke(Unknown Source)
at $Proxy254.lookup(Unknown Source)
2007-10-16 15:31:51,156 ERROR [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Reconnect failed: JMS provider failure detected:
at $Proxy224.lookup(Unknown Source)
at $Proxy208.lookup(Unknown Source)
2007-10-16 15:31:51,156 INFO [com.adobe.service.ProcessResource] BMC505: Service XMLFormService: Starting native process with command line "C:\\Adobe\\LiveCycle8\\jboss\\server\\all\\svcnative\\XMLFormService\\bin\\XMLForm.exe" -MyPath C:\Adobe\LiveCycle8\jboss\server\all\svcnative\XMLFormService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ppServer jboss
2007-10-16 15:31:57,924 INFO [com.adobe.service.ProcessResource] BMC508: Service XMLFormService: Native process PID = 2072
2007-10-16 15:32:01,190 INFO [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Trying to reconnect to JMS provider
2007-10-16 15:32:01,206 ERROR [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Reconnect failed: JMS provider failure detected:
2007-10-16 15:32:01,221 INFO [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Trying to reconnect to JMS provider
2007-10-16 15:32:01,221 ERROR [org.jboss.ejb.plugins.jms.JMSContainerInvoker] Reconnect failed: JMS provider failure detected:
Avatar
//THE SECOND
org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (java.sql.SQLException: Access denied for user 'adobe'@'localhost' (using password: YES))
at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:164)
at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.createConnectionEventListener(InternalManagedConnectionPool.java:519)
at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.getConnection(InternalManagedConnectionPool.java:208)
at org.jboss.resource.connectionmanager.JBossManagedConnectionPool$BasePool.getConnection(JBossManagedConnectionPool.java:529)
at org.jboss.resource.connectionmanager.BaseConnectionManager2.getManagedConnection(BaseConnectionManager2.java:410)
at org.jboss.resource.connectionmanager.TxConnectionManager.getManagedConnection(TxConnectionManager.java:342)
at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnectionManager2.java:462)
at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.allocateConnection(BaseConnectionManager2.java:894)
at org.jboss.resource.adapter.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:73)
at org.jboss.ejb.plugins.cmp.jdbc.SQLUtil.tableExists(SQLUtil.java:957)
at org.jboss.ejb.txtimer.GeneralPurposeDatabasePersistencePlugin.createTableIfNotExists(GeneralPurposeDatabasePersistencePlugin.java:92)
at org.jboss.ejb.txtimer.DatabasePersistencePolicy.startService(DatabasePersistencePolicy.java:96)
at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:274)
at org.jboss.system.ServiceMBeanSupport.start(ServiceMBeanSupport.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:141)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:80)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:72)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:245)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:644)
at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:960)
at $Proxy0.start(Unknown Source)
at org.jboss.system.ServiceController.start(ServiceController.java:428)
at org.jboss.system.ServiceController.start(ServiceController.java:446)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:176)
at $Proxy4.start(Unknown Source)
at org.jboss.deployment.SARDeployer.start(SARDeployer.java:285)
at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:118)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:74)
at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:127)
at org.jboss.mx.util.JMXInvocationHandler.invoke(JMXInvocationHandler.java:273)
at $Proxy38.start(Unknown Source)
at org.jboss.deployment.XSLSubDeployer.start(XSLSubDeployer.java:185)
at org.jboss.deployment.MainDeployer.start(MainDeployer.java:989)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:790)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:753)
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at $Proxy9.deploy(Unknown Source)
at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:319)
at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:507)
at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeploymentScanner.java:192)
at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentScanner.java:265)
at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:230)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:943)
Avatar
Bill,
Did reinstalling the server solved the problem. I'm having the same issue and can't get it resolved.
here's my post:
http://www.adobeforums.com/webx/.3c05bd72/2
Avatar
Level 2
Hi Roland,
I reinstalled to the latest LiveCycle ES Trial instead of the preview version and it worked. Also keep an eye on DB Password for turnkey installation. Even though you can change the password during installation it doesn't change every where. Default password for JBOSS Turnkey is "adobe".
Check in mysql-ds.xml, adobe-ds.xml, /server/all/conf/login-config.xml.
Also check your datasources in adobe-ds.xml, should have "IDP_DS","DefaultDS".
I'm currently running a manual configuration of LiveCycle ES Trial on Win Svr 2003 connecting to MS SQL Server 2005 on another Win Svr 2005 machine, all in a MS Virtual Server environment. This was configuration I required in the end. See post inregards to this configuration
Bill Kotsifas, "Problems Installing Livecycle ES in Virtual Environment" #, 29 Oct 2007 5:49 pm
Hope this helps.
Avatar
Bill, thanks a lot for your Reply, I finally solved it.
The DefaultDS was initially in the mysql-ds.xml file but I had renamed it to a custom name since I needed to have a datasource pointing to my own DB. I posted the details here: http://www.adobeforums.com/webx/.3c05bd72/5
Avatar
Level 10
"java.sql.SQLException: Access denied for user 'adobe'@'localhost' (using password: YES)"
Looks like you have a problem connection to the database.
Check the C:\Adobe\LiveCycle8\jboss\server\all\deploy\adobe-ds.xml and make sure the credentials are valid.
Jasmin
Avatar
Hi Guys, I solved the problem successfully.
in some versions of LiveCycle , specialy ver 8.0 while installation it dosn't save all the configuration in the configuration files, and that's cause a connection null get by the connection pool, so you should re-adjust the configuration file to make the Jboss succeed in getting connection to DB and that's by following these few steps
1. search on the LiveCycle Directory on these files (mysql-ds.xml, adobe-ds.xml, /server/all/conf/login-config.xml)
2. allow right access (make then not read only).
3. review all the password tags in connections "IDP_DS","DefaultDS".
4. check the password is that your password setled before in MYSQL installation; if not change it.
5. restart mysql service.
note: in some cases you might find the password is "adobe" by deafult if you find it please change it to your password
Good Luck
Ahmed Ibrahim
Avatar
Hi
I do get the same error while submitting the form. but one of my processes works and for other i get the same error where both the processes are identical and in fact share the same path where the form is being submitted what do i do?
