invoke remoting endpoint crossdomain
Avatar
Level 2
I need to invoke work process through remoting endpoint in flex app from other domain.
my flex app is on : http://localsever.me.com:9001/test.swf
in this test.swf, I try to invoke a process that is throught remoting end point
http://remote.me.comremoting/remoting/messagebroker/amf
I got error message with "Security Sandbox Violation" error.
Has anybody done this before successfully?
Joanna Gao
Avatar
Former Community Member
You can initiate request only on the same domain by default. If your swf is loaded from http://localsever.me.com:9001/ it can do remote calls by default only to the same domain. Otherwise you need a file called crossdomain.xml located on the other domain which will grant permission to your swf.
Read http://labs.adobe.com/wiki/index.php/Flex:Accessing_Data#Using_crossdomain.xml_files for more information
Avatar
Level 2
Thanks for the reply.
I am calling a livecycle service remoting end point, which is generated automatically by LiveCycle for each process.
Do you know where the LiveCycle app root directoy is so I can place the crossdomain.xml file in?
Joanna
Avatar
It would be in the app root of the application server that you are running ...not the LC application root.
Which app server are you using?
Avatar
If I goto http://hostname:8001 the location that this points to will be where you want to put it.
Avatar
Level 2
That is what I am trying to find out because there are 3 ear files deployed on the weblogic app server. but I am not sure where the port 8001 exactly points too.
Here is the folder structure under myApp server
Bea
-- user_projects
-- domain
-- LiveCycle
-- servers
--Admin
--MyApp
--Cache
--data
--logs
--security
--stage
--tmp
So which folder I should place crossdomain.xml file into? or I have to unzip the ear file to add it in?
Joanna
Avatar
Should be in the ear file (on root). But you can place the file in other places if you want and use Security.loadPolicyFile method
Avatar
Level 2
thanks!<br />I added the crossdomain.xml file into the ear file.<br />and used Security.loadPolicyFile("http://myserver.com:8001/remoting/crossdomain.xml")<br /><br />but flex just ignored my policy file saying: <br /><br />Error: [strict] Ignoring policy file at<br />http://myserver:8001/remoting/crossdomain.xml due to missing Content-Type. See http://www.adobe.com/go/strict_policy_files to fix this problem.<br /><br />Here is my crossdomain.xml. How should I add the content type? Can you provide me example? I am using Flash player 9<br /><br /><?xml version="1.0" encoding="UTF-8"?><br /><!DOCTYPE cross-domain-policy SYSTEM<br />"http://www.adobe.com/xml/dtds/cross-domain-policy.dtd"><br /><br /><cross-domain-policy><br /> <site-control permitted-cross-domain-policies="master-only"/><br /> <allow-access-from domain="*"/><br /> <allow-http-request-headers-from domain="*" headers="SOAPAction"/><br /></cross-domain-policy>
Avatar
Level 2
I have read all this. I know I need specify the content-type to be text/x-cross-domain-policy. but I am not sure how to do that..
Can you give me some steps how to change the content-type?
Thanks for the help
Avatar
Unfortunately I do not know WebLogic but I suppose that you can find this information in the WebLogic manuals - or you should find it somewhere on the web.
Avatar
Level 1
did you find a solution to this problem ? We are having the same issue when we deploy the crossdomain.xml to the weblogic server.
Avatar
Level 4
Not sure if there is a simpler way for Weblogic. Following way might work for you
-- Try creating an ear with a single war.
-- Specify the context root for that war in the ear's application.xml as /
-- Place your crossdomain.xml in the war
-- Deploy the ear
