Flex And LCDS
Avatar
Former Community Member
Hello,
For futur development, we need to choose a new Web oriented solution.
Flex look's like as we need because it's open source, Cross-platform,
AIR (deploy applications to the desktop), develop by Adobe, ...
When i'm look on Adobe's solutions, i'm quickly lose :  Flex, LiveCycle
Data Services Flex Data services, ColdFusion, ... plus components like AMFPHP.
So, I don't know what i need.
We want :
- Use PostgreSQL 8 as RDBMS,
- Flex as client,
- Connected mode (sessions management),
- Data push
If it's possible, we want it without any server-side language (PHP, Java, ...)
or use it as less as possible.
On Web, there is a lot's of example but when we search database connection ...
Cordially,
Avatar
Level 3
I would suggest looking into using Flex with LCDS 2.5.1 and its SQLAssembler
feature for Data Services where you can configure a destination and simply
provide the SQL for creating, retrieving, updating and deleting items directly
in the configuration - so no server side code to be written.
Avatar
Thank you for your answer,
Is what the management of persistence and sessions with LCDS is
possible? (without using java/tomcat/hibernate...)
Cordially,
Avatar
hi i m trying to use live cycle data services and java as back end but i get these errors when i try to get the data using fill method any idea where i m going wrong actually i m using data service and declare the service in service_config.xml and have the assembler class a service class and a java class to define the object and i get the following error
[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 404: url: 'http://localhost:8088/rajcon/messagebroker/amf'"]
at mx.data::ConcreteDataService/http://www.adobe.com/2006/flex/mx/internal::dispatchFaultEvent()
at private::DataListRequestResponder/fault()
at mx.rpc::AsyncRequest/fault()
at mx.messaging::ChannelSet/private::faultPendingSends()
at mx.messaging::ChannelSet/channelFaultHandler()
at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.messaging::Channel/mx.messaging:Channel::connectFailed()
at mx.messaging.channels::PollingChannel/mx.messaging.channels:PollingChannel::connectFailed()
at mx.messaging.channels::AMFChannel/mx.messaging.channels:AMFChannel::statusHandler()
Avatar
Hi All,
I would like to build an Flex/AIR application that initially provides LDAP authentication.
I am new to these Flex/Actionscript/DataServices however I have managed to get a nice datagrid querying & updating a MySQL Db from a Flex App using AmfPHP... Nice. I'm learning :-)
My question at the moment is what is the best/easiest way to enable LDAP authentication?
Could I use the following setup?
Flex/AIR IDE, LiveCycle Data Services ES Express, LDAP server?
Or do I NEED a j2SE server in there somewhere? or even a Coldfusion server?
I would like to try and avoid the need to include j2SE or Coldfusion servers at this stage.
Hope this makes sense.
TIA
Danny
PS: Thought I'd started a new thread, as I didnt I will re-post (apologies if I shouldn't)
Avatar
Hi ,
when i trying to retrieve the data from lcds server through Flex HttpService then i am getting this client.Error.MessageSend error ,can anyone guide me how to resolve this problem
Avatar
<b>Cannot get Data</b><br />Hello,<br />I having problem and im totally new to flex and cairngorm... here is my code snippet:<br /><br />im my java end:<br /><br /> List<Users> getAll() { // from hibernate dao then return result which llist of users }<br /><br />in AS files:<br /><br />public class ListDelegate extends EventDispatcher<br /> {<br /> private var userService:RemoteObject;<br /> private var responder:IResponder;<br /> <br /> public function ListDelegate(responder:IResponder)<br /> {<br /> this.userService = new RemoteObject("userService");<br /> <br /> this.responder = responder;<br /> }<br /> <br /> public function getUserList():void<br /> {<br /> <br /> var call : Object = userService.getAll();<br /> <br /> call.addResponder( responder );<br /> <br /> }<br /> }<br /><br />public class ListUserCommand extends BaseCommand<br /> {<br /> <br /> <br /> override protected function callDelegate():void<br /> {<br /> var listdelegate:ListDelegate = new ListDelegate(this);<br /> listdelegate.getUserList();<br /> }<br /> <br /> override public function result( event : Object ) : void<br /> {<br /> this.modelHelper.onResultUser(event);<br /> <br /> }<br /> <br /> override public function fault( event : Object ) : void<br /> {<br /> var faultevt:FaultEvent = event as FaultEvent;<br /> Alert.show(faultevt.fault.rootCause.toString());<br /> }<br /><br /> }<br /><br />public class ModelHelper<br /> {<br /> [Bindable]<br /> public var userlist: UserList;<br /> <br /> public function ModelHelper(userlist: UserList)<br /> {<br /> this.userlist = userlist;<br /> }<br /> <br /> public function getUserList():void<br /> {<br /> new ListUserEvent(this).dispatch();<br /> }<br /> <br /> public function onResultUser(event:Object):void<br /> {<br /> this.userlist.listusers = event.result as ArrayCollection;<br /> }<br /><br /> }<br /><br />..and i use DataGrid to display datas:<br /><br /><?xml version="1.0" encoding="utf-8"?><br /><mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml"<br /> initialize="init()"<br /> creationComplete="loadAll()" ><br /> <br /> <mx:Script><br /> <br /> import com.test.flex.util.UserList;<br /> import mx.rpc.events.ResultEvent;<br /> import com.test.flex.model.ViewModelLocator;<br /> import com.test.flex.events.ListUserEvent;<br /> import com.test.flex.model.ModelHelper;<br /> <br /> [Bindable]<br /> private var modelLocator:ViewModelLocator = ViewModelLocator.getInstance();<br /> <br /> [Bindable]<br /> public var modelHelper:ModelHelper;<br /> [Bindable]<br /> public var users:UserList;<br /> <br /> public function init():void<br /> {<br /> this.users = new UserList();<br /> this.modelHelper = new ModelHelper(users);<br /> <br /> }<br /> <br /> public function loadAll():void<br /> {<br /> this.modelHelper.getUserList();<br /> }<br /> <br /> <br /> <br /> <br /> </mx:Script><br /> <br /> <!-- mx:Label text="{modelLocator.test}"/ --><br /> <br /> <mx:DataGrid id="userlist" dataProvider="{modelHelper.userlist.listusers}"><br /> <mx:columns><br /> <mx:DataGridColumn headerText="ID" dataField="id"/><br /> <mx:DataGridColumn headerText="Username" dataField="username"/><br /> <mx:DataGridColumn headerText="Password" dataField="password"/><br /> </mx:columns><br /> </mx:DataGrid><br /> <br /> <br /> <mx:Button id="logout" label="LogOut" click="{modelLocator.modelWorkflowState = ViewModelLocator.LOGIN_SCREEN}"/><br /></mx:VBox><br /><br />..and the rest are straigthforward code. When I change the return value to String it works fine nut when put it back to List it display nothing or error i get but when i debug it i gets the results:<br /><br />11:20:14,459 INFO [STDOUT] Hibernate: select this_.ID as ID1_0_, this_.USERNAME as USERNAME1_0_, this_.PASSWORD as PASSWORD1_0_ from user this_<br />11:20:14,464 INFO [STDOUT] [BlazeDS]12/02/2008 [DEBUG] [Service.Remoting] Adapter 'java-object' called 'userService.getAll(java.util.Arrays$ArrayList (Collection size:0)<br />)'<br />11:20:14,465 INFO [STDOUT] [BlazeDS]12/02/2008 [DEBUG] [Service.Remoting] Result: 'java.util.ArrayList (Collection size:2)<br /> [0] = com.test.flex.model.User<br /> id = 1<br /> username = eman<br /> password = password<br /><br /> [1] = com.test.flex.model.User<br /> id = 2<br /> username = test<br /> password = password<br /><br />'<br />11:20:14,465 INFO [STDOUT] [BlazeDS]12/02/2008 [DEBUG] [Message.RPC] After invoke service: remoting-service<br /> reply: java.util.ArrayList (Collection size:2)<br /> [0] = com.test.flex.model.User<br /> id = 1<br /> username = eman<br /> password = password<br /><br /> [1] = com.test.flex.model.User<br /> id = 2<br /> username = test<br /> password = password<br />11:20:14,467 INFO [STDOUT] [BlazeDS]12/02/2008 [DEBUG] [Endpoint.AMF] Serializing AMF/HTTP response<br />Version: 3<br /> (Message #0 targetURI=/3/onResult, responseURI=)<br /> (Externalizable Object #0 'DSK')<br /> (Externalizable Object #1 'flex.messaging.io.ArrayCollection')<br /> (Array #2)<br /> [0] = (Typed Object #3 'com.test.flex.model.User')<br /> id = 1<br /> username = "eman"<br /> password = "password"<br /> [1] = (Typed Object #4 'com.test.flex.model.User')<br /> id = 2<br /> username = "test"<br /> password = "password"<br />1.228188014466E12<br />(Byte Array #5, Length 16)<br />(Byte Array #6, Length 16)<br />(Byte Array #7, Length 16)<br /><br />What im missing here?<br />Thanks a lot.<br />Cheers.
Avatar
How to communicate Flex with Html. When I closed the browser i want execute an event in flex application.Kindly help me to do this !
