Show 7 replies
1. Re: Preview PDF Tab
pguerett Oct 29, 2008 6:57 AM (in response to (mark_duxbury))The Preview tab makes a call to the Acrobat/Reader ActiveX control. Has it been disabled in your browser settings? If you reinstall Reader/Acrobat it should reset the activex control. -
2. Re: Preview PDF Tab
(mark_duxbury) Oct 29, 2008 7:05 AM (in response to (mark_duxbury))OK i will try that
Thanks -
3. Re: Preview PDF Tab
(mark_duxbury) Oct 30, 2008 12:28 AM (in response to (mark_duxbury))Thanks it worked ! -
4. Re: Preview PDF Tab
(David_W_Imrie) Nov 2, 2008 2:12 PM (in response to (mark_duxbury))I have Acrobat 8 and Reader 9 installed; How can i check if activeX has been disabled without reinstalling? David Imrie -
5. Re: Preview PDF Tab
pguerett Nov 3, 2008 5:44 AM (in response to (mark_duxbury))In your Internet Browser settings (I use IE). Under Options/Programs/Manage Add Ons. I in the list of progrms you shodul see Adobe PDF Reader as type ActiveX control. Make sure that this is enabled. If it is not there then it was never installed. Your system may be blocking the install of the ActiveX controls if it is not there. -
6. Re: Preview PDF Tab
(Guls) Nov 3, 2008 6:13 AM (in response to (mark_duxbury))just to avoid starting a new thread, I am posting a associated question, even I am preety new to LS world. I earlier had acrobat 7.0, after installing LS desginer. I uninstalled 7.0 and installed acrobat 8.1, but on preview tab when I right click and view "document properties" version shows 7.x. I wonder if LS designer actually previews with my 8.1 acrobat or not?. Is this correct?. -
7. Re: Preview PDF Tab
pguerett Nov 3, 2008 6:51 AM (in response to (mark_duxbury))It will preview with the default viewer. Probably 8.1 as it was the last one installed.
