Hello,
I need to connect to a database to pull some data to dynamically create a form based on the data I pull back. My SQL query works fine when I manually run it through a SQL client tool, but when I try to pass it through my workflow I'm having trouble with passing my string into the IN part of the statement. So if for example my SQL query is:
SELECT Field1, Field2, Field3 FROM Table1 WHERE Field4 IN (?)
I have a process variable that has the string I'm trying to pass into the ?, but I don't seem to be able to get the query to run. I have tried setting up my query to run as a Parameterized Query (passing my string process variable into the ?), and by setting the query up through xPath (where I am calling my process variable with an xPath declaration), but am not having any luck.
The process variable I am trying to pass is formatted such that I'm passing 'Value1','Value2','Value3' but I can reformat this string if need be. Even with using test data I can't get the query to return anything. For test data I have tried: 'Value1','Value2','Value3' ; Value1','Value2','Value3 ; Value1,Value2,Value3 but the query never returns any data. I can't seem to see how to format the string to pass into the query. The Query will work with a single Value in the test data, but as soon as I try to pass multiple values within the string it fails. Any suggestions?
