Learn about Edge Delivery Services in upcoming GEM session
How to Apply Usage Rights to an input form variable?
Avatar
Level 2
Hi everyone,
I have a process with an TaskManager (workspace) Endpoint. It has only one xfaForm input variable. The form is shown correctly in the workspace and the process runs fine.
But how can I apply Usage Rights to this (start) form? It's no problem to apply rights later in the process but I don't know how to do it for this first form.
I think it has to be done in the "Render Service" tab under "Advanced Settings" of the xfaForm variable. Any idea?
Thanks in advance,
Michael
Avatar
Level 10
See http://www.adobeforums.com/webx?128@@.59b53137
You will need to add the reader extensions step to the render service you are using on your xfaForm variable.
Jasmin
Avatar
Level 2
Hi Jasmin,
thanks for your quick response. If have seen the post. How can I add the reader extensions to the render service?
If I change the render service I lost all variables for the task.
Michael
Avatar
Level 2
Hi!
I have found the solution:
1. Create a new process with the default renderer component of the process management and any other component that is needed (in my case Apply Usage Rights)
2. Define this new process as render service of the form
Thanks in advance
Michael
