8 Replies Latest reply on Jun 15, 2008 1:00 AM by HowardTreisman
    Send form to parellel users
    johnqdaily Level 1
      I have a form that I want to route to a user and at the same time route it to a group for review. The user will make a decision on the form to accept or reject but the group will only receive the form to review and that's it (it's more for notification of the form than anything else).
      Any thoughts?
      John
        • 1. Re: Send form to parellel users
          Jasmin Charbonneau Level 4
          You can use the gateway object to do that.
          It's located under the Modeling Element view.
          Jasmin
          • 2. Re: Send form to parellel users
            HowardTreisman Level 1
            Hi John
            The problem with the gateway (and with a group) is that it's only one person within the group that actually gets to claim the form and view/action it.
            I suggest that what you do is something like:
            * Flatten the form (using LC Output) - this will make it non-editable and store it in a document variable. (If you don't have Output, just render the form as an editable PDF and store it in the document variable.)
            * Obtain a list of the group's member's email addresses
            * Use the Email component to send the flattened for to all members of the group.
            You can get a comma separated list of users in a group from this component:
            http://avoka.dnsalias.com/confluence/display/Public/Lookup+DSC
            and download from here:
            http://www.avoka.com/apps/checkcookie?qpac=y&qpac_code=avokaESComponents&location=%2Fapps% 2Fqpacdownload
            Howard
            • 3. Re: Send form to parellel users
              johnqdaily Level 1
              Thank you Jasmin and Howard for the reply.
              I do want to send this to a group so that either person in the group can take ownership and view it.
              I was having a problem with the gateway and couldn't get it to work like the LCES documentation showed. Basically I can't get the gateway to work because I don't think I am using it correctly. What does it need to connect to? What goes inbetween the gateway and how do I connect it?
              John
              • 4. Re: Send form to parellel users
                I can try to help...let's first be sure you've found all of the relevant documentation:
                general description: http://livedocs.adobe.com/livecycle/es/wb_help/00000502.html
                to add an operation to a gateway: http://livedocs.adobe.com/livecycle/es/wb_help/00000549.html
                to add a branch to a gateway: http://livedocs.adobe.com/livecycle/es/wb_help/00000548.html
                simple example: http://livedocs.adobe.com/livecycle/es/wb_help/00000561.html
                example of converging the branches after the gateway: http://livedocs.adobe.com/livecycle/es/wb_help/00000562.html
                example of a gateway inside a loop: http://livedocs.adobe.com/livecycle/es/wb_help/00000570.html
                I hope that helps. From here, we can perhaps use a topic as a reference point for further questions
                scott
                • 5. Re: Send form to parellel users
                  johnqdaily Level 1
                  Scott,
                  I have looked through the documentation you posted and I just got the gateway to work with and send with document email service. I was able to send the email but I couldn't get the attachment piece to work.
                  Here is what I need to do.
                  I have a process that sends the form that the user fills out, to their manager. At the same time the manager I would like a read only copy sent to a group (so that either person in the group can view it). The form going to the group is just for notification and they will not be doing anything with it but viewing it.
                  My problem is that I am not able to get it to them as a read only pdf form. I prefer that they view it in Workspace but email will do if I have to.
                  Thoughts? I have done a lot of testing in Workbench and multiple searches in the forum and am at a loss.
                  John
                  • 6. Re: Send form to parellel users
                    Level 1
                    did you "flatten" the form using Output before attaching it?
                    • 7. Re: Send form to parellel users
                      johnqdaily Level 1
                      I'm new to LC. What do I need to do in order to flatten the pdf? Does Adobe have an example or archive file that I can look at how it's set up?
                      John
                      • 8. Re: Send form to parellel users
                        You can alternately write some Javascript in the Form to iterate through all fields and make them read-only.
                        Howard
