Learn about Edge Delivery Services in upcoming GEM session
Cannot open process
Avatar
Level 3
Hello,<br /><br />I cannot open the process which i made some changes and saved it. I don't know what i did to make the server such angry with me!<br /><br />I get this in WB:<br />java.lang.NullPointerException<br /> at com.adobe.workflow.eclipse.template.AbstractTemplateDocument.initializeBranch(AbstractTemplateDocument.java:199)<br /> at com.adobe.workflow.eclipse.template.AbstractTemplateDocument.addPoolToDocument(AbstractTemplateDocument.java:1035)<br /> at com.adobe.workflow.eclipse.template.AbstractTemplateDocument.initializePools(AbstractTemplateDocument.java:138)<br /> at com.adobe.workflow.eclipse.template.ProcessTemplateDocument.init(ProcessTemplateDocument.java:59)<br /> at com.adobe.workflow.eclipse.template.ProcessTemplateDocument.<init>(ProcessTemplateDocument.java:54)<br /> at com.adobe.workflow.eclipse.editors.WorkflowEditor.createPartControl(WorkflowEditor.java:361)<br /> at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:183)<br /> at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:153)<br /> at com.adobe.workflow.eclipse.editors.WorkflowMultiPageEditor.createMainBranchPage(WorkflowMultiPageEditor.java:669)<br /> at com.adobe.workflow.eclipse.editors.WorkflowMultiPageEditor.createMainBranchPage(WorkflowMultiPageEditor.java:627)<br /> at com.adobe.workflow.eclipse.editors.WorkflowMultiPageEditor.createPages(WorkflowMultiPageEditor.java:206)<br /> at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:276)<br /> at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:596)<br /> at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:372)<br /> at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:566)<br /> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:290)<br /> at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:140)<br /> at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:268)<br /> at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)<br /> at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:394)<br /> at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1144)<br /> at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1097)<br /> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1311)<br /> at org.eclipse.ui.internal.PartStack.add(PartStack.java:455)<br /> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:102)<br /> at org.eclipse.ui.internal.PartStack.add(PartStack.java:441)<br /> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:111)<br /> at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:60)<br /> at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:217)<br /> at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:207)<br /> at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:820)<br /> at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:719)<br /> at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:680)<br /> at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2593)<br /> at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2528)<br /> at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPage.java:2520)<br /> at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:2505)<br /> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)<br /> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2500)<br /> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2477)<br /> at com.adobe.workflow.eclipse.views.ServiceRegistryProcessesView.openWorkflow(ServiceRegistryProcessesView.java:1371)<br /> at com.adobe.workflow.eclipse.views.ServiceRegistryProcessesView.editWorkflow(ServiceRegistryProcessesV
Avatar
Level 3
Yes, restarted workbench and LC server, but did'nt work..
Avatar
Level 9
It seems like your process has been corrupted in some way.
Can you export it?
(Not a LCA file, just the process itself as xml.)
If so, try exporting it, and then re-importing it.
If you can export it, you can send it to us support-at-avoka.com, and we'll have a look.
Howard
http://www.avoka.com
