Learn about Edge Delivery Services in upcoming GEM session
Assign Task - Saving completed user ID
Avatar
Level 3
Hello,
It saves the GUID (Global Unique Identifier) only. How can i see the name or the code like 'apink' .
Avatar
Level 10
With LC ES update 1, you'll be able to use a user service to get that information.
In the current build, you can do an API call or use the JDBC service to query the database.
You can do something like SELECT * FROM edcprincipaluserentity where refprincipalid = 'GUID'
Jasmin
Avatar
Former Community Member
Jasmin, which service do I call to retrieve the real user ID, given the GUID/ I have update 1 now, but don't see which service to use.
Avatar
nevermind, I found out. Using the UserManagerLookupService and the Fidn User service operation, I passed in the Task - User's ID which is the GUID. I created a user variable in the custom render process and assigned the output of Find User to that variable. I then used a SetValue service to set the user's user ID (real login id) to another variable of type string. It works great.
