I want to use JDBC Service in Workbench ES to insert data into a MS SQL Server 2005 database.
I defined my database in Jboss's configuration file (C:\Adobe\LiveCycle8\jboss\server\all\deploy) as:
SQL_SRV
jdbc:microsoft:sqlserver//localhost:1433/LCTest
com.microsoft.jdbc.sqlserver.SQLServerDriver
LCTest
password
10
30
20000
10
100
TRANSACTION_READ_COMMITTED
And in Workbench I specified the datasource as java:/SQL_SRV. When I try to test my connection with a simple sql statement I get the below exception:
java.lang.NullPointerException
at com.adobe.idp.dsc.jdbc.editor.sql.SqlStatementInfoContents$1.widgetSelected(SqlStatementInfoContents.java:146)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at com.adobe.idp.dsc.editor.base.PopupEditorComposite$1.widgetSelected(PopupEditorComposite.java:58)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.lcide.rcp.Application.run(Unknown Source)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Finally my question is.. What am I doing wrong?
Thanks.
