Problem with JBoss and Servlets
Avatar
Former Community Member
I have 2 questions that are related. I'd appreciate it if anyone can address either or both questions...
(1) We installed the turnkey LiveCycle ES on a windows box with JBoss. Ih ave built a servlet that will invoke a renderPDF orchestration and show a PDF. I followed the sample given at: http://www.adobe.com/devnet/livecycle/articles/java_servlets.html
When deploying and attempting to test on the LC ES server, I am getting 404 errors. I decided to see if JBoss was up and running normally and I went to http://localhost:8080/ and see a JBoss page with JBoss Onlien REsources links at the top and JBoss Management links at the bottom. The links go to Tomcat Status, JMX Console and JBoss Web Console. All 3 links at the bottom return 404 error messages. Workspace works just fine on this machine. Web Service calls also work fine. What could be wrong?
(2) I decided that since the app server on the LC ES server was malfunctioning, I would install TomCat on my desktop and then just run the servlet with remote calls to the livecycle server. I am getting error messages in the logs "stdout_20080919.log" saying that I have a java.lang.IllegalStateException. I set up the connection properties to include the full server name, not just localhost, so it looked like: jnp://servername:1099.
Any help would be greatly appreciated.
Avatar
Level 10
I think your appserver is fine in (1). You'll get a 404 error for the JMX Console and possibly the other links (under :8080/) because we've removed those modules for security reasons.
Now to make sure the service is running fine can you try to hit the wsdl. The url is typically http://localhost:8080/soap/services/NameOfService?wsdl.
Now are you packaging your servlet in a war file? The typical URL would be http://localhost:8080/NameOfWar/NameofClass.
My guess is the project is not packaged properly.
Jasmin
Avatar
Hi Jasmin,
The WSDL works just fine. I have also started "recording" of the process in workbench but it is never invoked via the servlet. I did in fact package the servlet in a war file and used the typical URL as you describe above. I am using eclipse to build and package the servlet. Should I post the log results or my java code?
Avatar
UPDATE
I changed the package and made sure the libraries were included. I still can't get it to work on my desktop, but I redeployed to the LC ES server and it definitely invoked the process. I see it in the playback. And I can see the output PDF document during the playback. Unfortunately, in the browser, I don't see anything but a blank screen. No PDF.
Thoughts?
Avatar
CODE BELOW:
import java.io.IOException;
import java.io.InputStream;
import java.util.HashMap;
import java.util.Map;
import java.util.Properties;
import javax.servlet.ServletException;
import javax.servlet.ServletOutputStream;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import com.adobe.idp.Document;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.idp.dsc.clientsdk.ServiceClient;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
import com.adobe.idp.dsc.InvocationRequest;
import com.adobe.idp.dsc.InvocationResponse;
import com.adobe.livecycle.formsservice.client.FormsResult;
* servlet implementation class for Servlet: TestGetForm2
public class testGetForm2 extends javax.servlet.http.HttpServlet implements javax.servlet.Servlet {
static final long serialVersionUID = 1L;
public testGetForm2() {
super();
/* (non-Java-doc)
* @see javax.servlet.http.HttpServlet#HttpServlet()
/* Just calls the doPost method. EJC 09/18/08
* @see javax.servlet.http.HttpServlet#doGet(HttpServletRequest request, HttpServletResponse response)
protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException
doPost(request,response);
/* (non-Java-doc)
* @see javax.servlet.http.HttpServlet#doPost(HttpServletRequest request, HttpServletResponse response)
protected void doPost(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
try{
String lanIDConst = "XXXXXX";
Properties connectionProps = new Properties();
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT,"jnp://servername:1099");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, "JBoss");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "xxxxxxx");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "xxxxxxx");
//Create a ServiceClientFactory object
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
//Create a ServiceClient object
ServiceClient myServiceClient = myFactory.getServiceClient();
//Create a MAP object to store the parameter value
Map params = new HashMap();
//Populate the Map object with a parameter value
//required to invoke the TestServlet process
params.put("lanID", lanIDConst);
//Create an Invocation request object
//the last argument is set to true because this is a short-lived process
InvocationRequest esRequest = myFactory.createInvocationRequest("TestServletRenderPDF", "invoke", params, true);
//Send the invocation request to the process and get back an invocation response object
InvocationResponse esResponse = myServiceClient.invoke(esRequest);
FormsResult formOut = (FormsResult)esResponse.getOutputParameter("outFormDoc");
//Create a document object that stores form data
Document myData = formOut.getOutputContent();
//Get the content type of the response and set the HttpServletResponse objects content type
String contentType = myData.getContentType();
response.setContentType(contentType);
//Create a ServletOutputStream object
ServletOutputStream oOutput = response.getOutputStream();
//Create an InputStream object
InputStream inputStream = myData.getInputStream();
//Get the size of the InputStream object
int size = inputStream.available();
//Create and populate a byte array
byte[] data = new byte[size];
inputStream.read(data);
//Write the data stream to the web browser
oOutput.write(data);
}catch (Exception e){
e.printStackTrace();
Avatar
Level 10
What's the value of the "size" and "contentType" variable in your code?
Jasmin
Avatar
Hi Jasmin, thanks for your reply. I'm getting closer to a solution.
It's choking on the line FormsResult formOut = (FormsResult)esResponse.getOutputParameter("outFormDoc");
I double checked my process and the output variable "outFormDoc" is not set to variable type "FormsResult". It was set to "Document". When I change the variable type to "FormsResult", it crashes in the process in the Render Form (renderPDFForm) activity when I assign the outFormDoc variable. It says "invalid location: /process_data/@outFormDoc cannot be stored for action instance -1"
My settings for the renderPDFForm activity are:
Input:
Form to Render -literal value = "/POC/getHRInfo.xdp"
Form Data = blank (no data to merge)
Stand Alone Rendition = True
Form Model = Client
Application WEb Root = Blank
Target URL = Blank
Content URI = repository://
Base URL = Blank
Output:
Forms Result = /process_data/@outFormDoc where outFormDoc is of type FormsResult
Thanks for your help!
Avatar
IT'S WORKING
I changed the output Forms Result to a "variable" instead of "XPath expression" and it works just fine now.
Thanks for your help Jasmin!
