Hello,
I´m trying FormGuide. I realize that the behavior of the script inside an event in a pdf/template is different when the pdf is opened directly in acrobat reader or when is opened using a formguide (preview pdf).
For instance, if I have 2 javascript alerts on the change event of a field, only the first one will be shown when the value of that field is changed in formguide.
Another example: if at the same event I have a javascript replace funcion, when I change the field in the guideform, the event is fire as expected, but I will get an xfaxm error message...
I thought formguide would only make a mapping between the field in the flash screen with the field on the form, but that everything else would run inside the form. However, it seems formguide is "capturing" the events and script and is running them...
If this is true, how can I define something like a replace function?Also, How can I use floating fields in a pdf, that will be changed as some field in formguide changes?
Thank you
