Hi Jasmin,
Thanks for the documentation link but i have the same question about changing the default type dm_document to something like pdf. Basically I could do that as part of the orchestration while storing the document in documentum.
But - if i switch the liecycle repository to documentum so instead of using the default livecycle repository i am using the documentum then the documents (pdf templates, fragments, asset objects etc) gets put into repository as dm_document type. I search into the adminui but couldn't find any configuration setting.
Can you please check with the team and advise if we can change the document type for the objects that get put into repository?
Cheers,
Parth
