Retrieval of email address from email endpoint
Avatar
Former Community Member
Hello everyone,
Can someone please let me know if there is any way to get the email address of the person when a process is invoked through email endpoint? I mean the email address from which an email is received which invokes the process.
Sunaif
Adobe Consultant
Avatar
Level 8
Level 8
Hi Sunaif,
You can make a string as an extra input variable and in the mapping in the endpoint setup (in AdminUI) your set the value to %SENDER%, this should give you the email address of the sender.
Let me know if this works for you
\Kim
Avatar
Hi Kim,
Yes it worked for me... thanks :)
Sunaif
Avatar
can we get the filename of the attachment from the endpoint?
Avatar
Hi !
I was seeking for this kind of information,
[use of %SENDER% to get the sender's email for an Email Endpoint]
but I cannot find this information on the Adobe documentation !!!
Where do you find it ?
I'm facing the same problem to get the Subject and the Body fields.
For the Subject, I simply put %SUBJECT% to make it possible.
BUT, for the Body, I tried multiple variations : %BODY%, %MESSAGE%
without success. If someone can help for this field ?!
Finally, is it possible to tailor the email sent with the results ? I mean it could be useful to fix the content of both the subject line (something different from "Results from LiveCycle ES") and the body.
Or another possibble approach should be to disable (how ?) the
sending of the result (by the Endpoint itself) in order to let
the service doing the sending job with all the wanted params.
Thanks a lot,
BG.
Avatar
Level 10
This is documented in the help from adminui.
When you setup your email endpoint click on the Application and Services help (top right corner of the page).
Then in the Adding endpoints to services section click on
Email endpoint settings.
Jasmin
Avatar
After extensive researches,
the provided documentation (for download) was not up-to-date at all !
I found the mention of the %SUBJECT%, %SENDER%, %BODY% and %HEADER%.
All are working EXCEPTING the %BODY% which has a big bug !
Under classic circumstances where you provide a simple text/plain
for the body of your email, LC doesn't map it to the %BODY% field.
(this last one remains EMPTY).
If you create a "rich" body with the type "text/html", the body
of the message is correctly mapped to %BODY% !!!!!!!!!!!
For the rest,
Can we imagine to initiate a service using an email endpoint
and provide the results by dropping them into a folder WITHOUT
receiving any message from LC ?
BG.
Avatar
Level 10
Make sure to open a bug with support.
Jasmin
Avatar
You can disable the sending of the results back from the endpoint. If you go to the "Add Endpoint" screen in adminui and click on the help icon, you can see the following information under the email endpoint configuration settings:
Recipient Successful Job
An email address to which messages are sent to indicate successful jobs. By default a successful job message is always sent to the sender. If you type sender, email results are sent to the sender. Up to 100 recipients are supported. Specify additional recipients with email addresses, separated by commas (,).
To turn off this option, leave the attribute blank. There may be some cases where you want to trigger a process and do not want an email notification of the result.
Recipient Failed Job
An email address to which messages are sent to indicate failed jobs. By default a failed job message is always sent to the sender. If you type sender, email results are sent to the sender. Up to 100 recipients are supported. Specify additional recipients with email addresses, separated by commas (,).
Justin Klei
Cardinal Solutions Group
Avatar
Hi Justin Klei !
I thought they were mandatory fields !
Thanks a lot !!!
BG.
Avatar
George,
Could you figure out how to make %BODY% work? We are having the same issue. Everything else gets populated (subject, sender etc) into string field on the form but not the body. BTW we use Groupwise for emails.
Kumar
Avatar
sgomatham,
I opened a case at the Adobe Support some days ago.
For me, it's clearly a bug and you can easily reproduce it.
Until now, I found only one workaround which is not acceptable
for our needs : Provide a Text/Html body with at least one attachment !
I'm waiting for the feedback from the Support.
I can keep informed,
George.
Avatar
Level 9
If this is critical for you, you can "roll your own" Email endpoint using a looping process. It will contain Email>receiveEmail, a Wait step, and a sub-process invocation.
If you need more help, read this "Patterns" paper, which describes how this used to be done in the days before watch folders.
The details are different, the principle is the same.
http://www.avoka.com/resources/resources/TheWatchFolderPattern.pdf
Howard
