Hi again Jasmin,
ANd once again - thanks for the clarification, I still have a lot to learn :)
"Assembler is part of the foundation. If you bought Process Management, then you can use Assembler."
Weird, I just checked the server at the customer site (currently a version 8.0 - but will get upgraded to 8.2 before the process will be installed) and there was no Assembler under Common, I have found it under common on my own development server.
"That's I've never seen. Where do you get this message from?"
I stand corrected - You are absolutely right on this one, I had made some other thing wrong that made this warning pop up.
"You ave to use a Document Form when you want to use a PDF and (most importantly) submit a PDF form a User step."
I am not sure how to use the Documént Form, should I set the /process_data/myDocForm/object/document = /process_data/myDocument and then set the "/process_data/myDocForm" as the input document (or should it be "/process_data/myDocForm/object/document") under Form Data Mapping in the Assign User step?
And what should the Output Form Data in the Assign User step be set to?
I can't seem to set it up right - I can get the User step to show the Document Form, but no changes are stored when I take one of the routes out of the User step. I think I have made the PDF submit PDF correctly, but this does not change anything.
Thanks in advance
Sincerely
Kim
