Script component set get / ProcessDataValue
Avatar
Former Community Member
Inside the script cmponent how can I set and get the process data
which is either Object or custom Object?
I found some info at on these methods
patExecContext.setProcessDataValue(aPath, aVal)(aPath, aVal)patExecContext.getProcessDataValue(aPath)
at http://kb.adobe.com/selfservice/viewContent.do?externalId=kb402587
but it is not working as mentioned but getting error (see below) any clue why?
Yog
Target exception: ALC-DSC-119-000: com.adobe.idp.dsc.util.InvalidCoercionException: Cannot coerce object:
Avatar
Level 10
What variable type are you trying to set?
For example if you want to set a string you can use setProcessDataStringValue(path,value) although setProcessDataValue() should work.
Jasmin
Avatar
It is the custom veriable type. ( A custom component exports this custom data type note: I can see this variable type while creating new variable so it is visible to LCWB)
Yog
Avatar
// I able to overcome InvalidCoercionException error it was classpath problem but still not able to get it work getting null pointer
// ok here is simple test script TestExport is just plain POJO
import TestExport;
TestExport testExport = new TestExport();
System.out.println(" TESTING NOW 1");
testExport.setName("YYYYYYY");
System.out.println(" TESTING NOW 2");
testExport.setId("IDDDDD");
System.out.println(" TESTING NOW 3");
patExecContext.setProcessDataValue("/process_data/testExport", testExport);
System.out.println(" TESTING NOW 4");
TestExport testExport2 = (TestExport) patExecContext.getProcessDataValue("/process_data/@testExport");
testExport = (TestExport) patExecContext.getProcessDataValue("/process_data/@testExport");
System.out.println(" TESTING NOW 5"); // till here get printed
System.out.println(" testExport2 is here = "+ testExport.getNameID() );// throw null pointer
System.out.println(" testExport2 is here = "+ testExport2.getNameID() );// throw null pointer
System.out.println(" TESTING NOW 6"); does not print this
Avatar
Level 10
What is the type of /process_data/testExport in Workbench? Did you create a custom data type called testExport? Or you used Object?
Jasmin
Avatar
Hi Jasmin,
The type of /process_data/testExport in Workbench is TestExport, I created a custom data type called TestExport inside package mycommonpackage.
The component that export this datatype has component.xml with export as below.
mycommonpackage
Another related question: when does the custom component start showing up inthe xpath builder under property tab?
Yog
